Question about Dell Latitude 120L Notebook
Laptop will not charge.
The laptop type is : Dell lattitde 510
The laptop will not power up from the mains supply or charge the battery. The power supply is working, the power is getting to the mother board but is not switching. Have used a voltage test meter over various parts of the board with the power on very minute power (0.25 V) to the battery pins. Computer will work off the battery as normal but I am unable to use it for long as the life of the battery is not long. Between the power into the mother board to the battery terminals there is a ault and can not find it.
Any ideas? Many thanks Craig.
    Problem Solver:
  • 16 Answers
Bad system board. not much more than that. or the ac adapter may have the green light on but nothing coming out the low voltage side. i am going with that the power module which intergrated into the system board is bad. needs to be replaced.
Posted on May 22, 2009
Red indicator blinking
does laptop work without external power supply,if no then Battery probably not charging Dell computers don't like oem power supplies as often need specific dell charger to suit model laptop so that laptop will recognise it and allow battery to charge
Aug 09, 2014 | Dell Precision M4300 Laptop AC Power...
How to switch the laptop to ac power source
Connect the mains charging adapter to the laptop and it will automatically run off the mains supply as well as charging the laltop battery.
Apr 08, 2012 | Dell Inspiron 1200 Notebook
My dell studio 1737 has gone dead.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Many people have reflected that Dell's notebook haven't recognised and charged the new battery problem. Usually, they solve this problem via BIOS refreshed.
Usually, please connect the battert with the power supply when you can refresh the BIOS. You can download the BIOS program from Dell support website http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=dell+bios+inspiron+6400&cat=sup, automatically installed and automatically restart till to complete. Of course, you could check its use manual in advance.
Or you can visit http://www.batteriescenter.com.au/.
Mar 25, 2012 | Dell Studio 1737 Laptop
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
No laptop power from mains or battery
just remove the RAM chip and try to power on
then clean the ram and re install it then check.
Oct 05, 2009 | Dell XPS M1330 Laptop
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Battery will not charge
Hi cdravi
Laptops have a power supply control section attached to, or part of the main board. This allows the laptop to switch charging on and off, and control power supply function to different areas of the machine. Sounds like you have a fault in this part of the computer. Off to Dell Service for that one I am afraid.
robotek
May 05, 2008 | Dell Latitude C610 Notebook
Power supply will not charge battery on lattitude d 510 laptop
It may not be the power supply. The Battery can only take 500 charging cycles in it's lifetime. the battery could have failed or the chip on the motherboard that regulates voltage to the battery may have failed.
Easy test for power supply is with battery removed if it still powers up the laptop than the voltage and amperage are sufficient.
Mar 27, 2008 | Computers & Internet
Dell Latitude 120L Notebook Logo
176 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
