Question about Gemini Sound Products UF-1264L Professional Microphone
No signal on receiver,
I work in Spain,using this system with no problems.For 10 days now it wont work,or works occasionally.There is no signal on the receiver on any of the 64 possible frequencies.Could something outside be causing this problem,as the system itself is not broken?This has happened before,and then returned to normal after a week or so.But drives me crazy when trying to work.Thanks.
I live in Spain and bought the Syphony 3325 in England. I am trying to use it in Spain, but it won't work. Any help would be appreciated
Dear An Onymous,
There could be several reason you are having problems.
I should first suspect the electricity that powers it.
I think England and Spain use different electricity, perhaps both the voltage and the Hertz may not be the same.
Then there is the telephone signal that you are trying to receive. Those signals may be different from England to Spain.
I would recommend to try to contact the company in England from which you purchased the Symphony, and see if they can help you. God bless your efforts.
May 24, 2016 | Miscellaneous
Does not find GPS signal in Spain
It may help if you regularly get the latest satellite positions (for the next 7 days) - QuickGPSfix data (via TomTom HOME).
Jun 19, 2013 | Tomtom GO 700 GPS Receiver
Weak audio static uc2-ub handheld
Sounds like either local interference or it needs to go to Shure for repair. Can you try it in another location maybe 10 miles or further away from the present location. If it operates in the MHz band you need to replace it, it is illegel to use that band in the US..
Mar 13, 2012 | Shure Beta 87A Professional Microphone
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
My receiver does not gen any signal and turns on and off by itself ....last time that that happen i unpluged the system and leave it for a couple of days thinking it was broken but it worked ...... And it...
Hello there could be a coupledifferent issues that are going on, the first is your receiver is in "BootRecovery" and it can take 45 minutes to 4 hours. The other could be connectionsfrom the back of the receiver to the wall need to be hand tight and unplugthe receiver for 10 seconds to reset.
Mike Houston of DISH Network
May 15, 2010 | DISH Network ViP 211 DTV Receiver
Factory speakers on 95 camaro wont work.
loose wires a short behind ur reciever when ya put it in
Jun 16, 2009 | Alpine CDA-7894 CD Player
Surround sound not working
Bad DSP board (digital signal processing board)- a common problem for Denon receivers. Hope you have a warranty.
Apr 06, 2009 | Denon AVR-4306 Receiver
My tom tom ONe cannot get a valid Satelite Signal just stays wait
If you are indoors then move outdoors to get a signal.
If you are outdoors then move your location by a few yards and sometimes it will suddenly aquire the satellites.
Happens occasionally with my unit. I normally set a route up then start driving and it suddenly starts to work OK.
HTH
Peter
Mar 07, 2009 | Tomtom ONE GPS Receiver
2001 Blazer Signals, need to be changed or refurbised
could do with somewhere like this in alicante spain,here its original only.So i can only suggest dealers and renew the stalk control
Jan 11, 2009 | 2001 Chevrolet Blazer
Garmin GPS acquiring satellite Issue
I would return it to Garmin for service.
Mar 23, 2017 | Garmin nuvi 200W GPS Receiver
Gemini Sound Products UF-1264L Professional Microphone Logo
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
richie46
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
