Question about Frigidaire GLTF2940ES Front Load Washer
Washer has water but doesnt spin frigidaire gl2940es
Checked pump found a quarter,loud hum heard when going to spin cycle,did diagnostic test found communication problem checked wires good whats the next steps i should take????
  • 3 Answers
WASHER DRAINS BUT WILL NOT SPIN AT ALL
Posted on May 24, 2009
Washer cycle not starting
Did you read the user manual of your whasher? Unplug the washer to the wall out let and then verify carefully whats going on. maybe some unwanted material in it..check all the necessary components and test again.
notify me for what did you notice. melnavz
Apr 09, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Frigidaire front load washer e21 error appears after running about 20 mins into the wash cycle,i check the clothes they are still wet,although no water is still left,i go to the spin only cycle to get the...
Hello debbiecantu1 - Typically error code E21 indicates an issue with the water not pumping out fast enough. Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Dec 13, 2012 | Frigidaire ATF6000ES Front Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Washer Model #WILL-1 - won't spin or pump out water
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Nov 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Something is stuck in the pump. Remove the hoses and remove the items. It will probably be a coin.
Jun 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool duet post washer 2006 model will not start any cycle and only hums and pumps odl water out
Sounds like your pump is clogged....first you need to remove the front cover below the loading door... (will be 3 Phillips screws on the very bottom). You will see a white cap in the very center bottom. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins wrappers...ect... I made about $2.75) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover if the normal cycle doesn’t go all the way through.....then you got me.....the pump is probably out but you will get more information if you run the diagnostics.....Good Luck.....
Sep 21, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
256 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
