Question about Sharp AR-235 Copier
How to tell if the ar235/275 has the faxing opition
I am looking at buying a used ar235/275 copier and seen the control pad has butons for faxing and scaning how can you tell if the unit has those opitions, I looked and did not see a phone jack any were, i did see 9 and 32 pin connectors ..
    Scholar:
  • 95 Answers
Those are options that are available, but if it doesn't have a phone line input (RJ45) then it doesn't have the fax board in it. You will have to turn it on and press those buttons to see if they are installed or not. Thats about the only way to find out if current owner doesn't know. Check the cost of drums/toner before you buy any used machine because that may be a deal breaker for you if the toner is $250 and the machine was only $100.
Posted on May 22, 2009
Left buton in touchpad in hp probook 4530s doesnt work
Sounds like a faulty switch under the button. Have a look on ebay for a replacement.
Feb 10, 2014 | HEWLETT-PACKARD ProBook 4520s
My printer is Cannon mp258 I cannot use it because of the error p08 how can i fix it?
the error P 0 8 means that the ink level in the cartridges is not recognized.
On the printers control board you have a buton that is called Resume/Cancel, it is the buton near the copy black and copy color butons. You can recognize it by the red triangle in a red circle.
Press this buton for at least 10 seconds, if the error is not gone from the first time press and hold the buton for at least 10 seconds for the second time.
Dec 02, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Multiple pages
Actually, when you get more than one paper feeding in at a time, it is almost always the separation pad being worn down. Go here to buy a new sep. pad and tell them Ken from National Cartridge Co. sent you there!
http://www.precisionroller.com/paper-feed-components-for-brother-intellifax-5750e/details_9248.html
May 28, 2010 | Brother IntelliFAX 5750e Laser Fax
My printer says incorrect port detected
Hi, Malcolm.
Boot your system to Safe Mode (press F8 repeatedly).
Login as Administrator (no password).
From the Control Panel, click on Printers & Faxes.
Right click on the Printer and select Properties. In the Advanced tab, tell it to Print Direct to Printer instead of using the Spooler..
It's a problem often seen on XP Home where a Symantec product (like Norton A/V) is installed.
Hope this helps.
Oct 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
Looking to buy fax attachment for machine
I have a used, but fully functioning kit. I also have the instructions, but you may require further assistance that I can't provide - there are circuit boards, and connections that need to be installed.
Email me here if you like:
sandy_macneill@hotmail.com
Mar 13, 2009 | Ricoh Aficio 450 Copier
It says my printer spoiler is not working. what is that
go to control panel then printer and faxes
sele ct your printer properties then go to advanced
enable option buton to sppool so progeam finish faster.
aslo enable print directly printer.
Nov 11, 2008 | Lexmark Office Equipment & Supplies
Faxing
Normal 0 Sending Fax Using Calling Card:
Load document in the ADF
Press [FAX]
Adjust settings for your documents as necessary
Press [Hook] Alternatively, you can lift the handset if one is connected to the machine.
Dial your calling card information responding to all calling card prompts on the fax key pad. After dialing the recipient’s number using the numeric keys or speed dialing, wait for the high-pitched fax signal.
When you hear a highpitched signal, press [Black} for black & white sending.. Hang up the handset if you used it.
Oct 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Toshib E-450 fax confirmation.
Press the user functions button on control panel
Press Admin button and key in password and then ENTER
press the LIST/REPORT button
press report settings
press COMM.REPORT button
then press desired butons for each item
press enter
hope this helps!
C
Aug 22, 2008 | Toshiba Saddle-Stitch Finisher Copier
Canon Pixma MP780
Yep your printer is nearing service time. This involves changing the waste ink pads and resetting it.
you could reset the printer without changing the wate ink pads but you risk damaging it
What i do is take the pads out wash them and replace them.
the waste ink pads are the pads the cartridge rest on whan itsn in neutral position
THE SERVICE MANUAL FOR YOUR PRINTER *step by step instructions in repairing it) is here
http://www.nodevice.com/manual/Canon/page15.html
and here
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
enjoy
Dec 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Sharp AR-235 Copier Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
