Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Need to change chain
I need to change the chain
  • 3 Answers
Go buy a chain that is the right size. As you are holding the saw on the left you will one or probably two nuts on a screw. Remove them and then remove the cover over the sprocket and chain. Remove the old chain and install a new one. Make sure the teeth are in the same direction as the old chain!!! Pull on the bar until the chain is tight. Reinstall the cover and tighten the nuts back up. You are good to go.
Posted on May 22, 2009
Where are timing chain tensioners? I need to change them.Does left one have an electrical connection? Thanks
The timing chain tensioners are located with the timing chain inside the timing cover and usually are not changed unless the timing chain assembly is replaced. Why would you change them?
Dec 29, 2015 | 2003 Ford Explorer Sport Trac
When is the timing chain of a 2007 1.5 4x4 daihatsu terios changed?
Timing chains do not need changed until they break or get so loose that they jump a tooth on the chain. But if you have a timing belt instead of a timing chain, it does need to be changed before it breaks. Replace the timing belt every 60,000 miles. Severe engine damage will occur if you do not replace the timing belt every 60,000 miles.
Aug 14, 2015 | Daihatsu Cars & Trucks
Knocking noise of chain
How many miles have you put on the chain.
You may just need a new chain and sprocket set.
As these do wear over a period of time.
Have you been lubricating the chain regularly ?
if this is an O ring chain, they rely on the oils in between.
If you need to change the chain, look at an X ring chain, these suffer wear less quickly.
Apr 03, 2014 | Motorcycles
Does a kia rio diesel 56 plate need the timing belt changing or has it got a chain
The engine which is made by Mercedes is not belt driven, it has a timing chain, timing chains never need to be replaced unless they fail or the engine is being rebuilt.
May 17, 2012 | Cars & Trucks
Does it have a timing belt or chain and when does it need to be changed
Hello there and than you for choosing fixya
Your vehical has a timing chain see the pict and price below around any where around the 100 to 120,000 mile mark the chain should be changed
Timing Kit/component/Timing Chain
Price:
$33.99
Mar 30, 2011 | 2002 Jeep Liberty
Need to change the timing chain? Can you change the chain and nothing else???
Hello yes you can change the timing chain and nothing but but it would be wise to put the two gears on at that time that comes with the chain.
Jan 03, 2011 | 1991 Ford Ranger Supercab
Timing chain how often does the timing chain need to be replaced???  2002 bmw 745i 118000 kms
There is much talk "supermans mechanics" when timing chain change, but as a mechanic BMW (E65certificate) I do not know about any interval exchange! BMW tell us instructions timing chain is lifetime and no change
May 15, 2010 | 2002 BMW 7 Series
Do you need to change the timing chain on a 2003 Jeep Grand Cherokee at 75,000 miles?
You will not need to change a timing chain unless you know or suspect it to be bad. Belts and other material that wear down need to be changed but the timing chain itself is a metal similar to that of a bike chain but much shorter and thicker
Oct 24, 2009 | 2003 Jeep Grand Cherokee
I don't find any reference to changing a timing belt or chain on my 3.0L 2005 Escape XLT. Please clarify need to change belt or chain (which?).
twin chains. no need to change. timing belts are the ones that need to be changed sometimes as often as 40,000miles/60,000km!
Aug 04, 2009 | 2005 Ford Escape
Front right fork, suspension,chain guide
chain needs adjusting or new chain needed, shouldnt be that sloppy, and change both fork seals toghther, its a false economy to change just one, if you do the other will go within a month and cost you double to have the forks removed twice. these are fast bikes and need good maintenace, you would do 180mph with a dodgy fork seals and dodgy chain.
Jul 30, 2009 | 2003 kawasaki ZX-9R
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
162 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
