Question about Dane-Elec DaneElec 2GB USB Drive Red Hard Drive
The computer doesn't read the flash drive when i plug it into the USB port
When i plug in my flash drive the computer does not read it. How do I fix this?
    President:
  • 1,383 Answers
Go to my computer property then hardware then device manager then uninstall usb drivers and install again
if u find unknown device u must have to install proper flash drive driver
Posted on May 22, 2009
3 Suggested Answers
SOURCE: beeps and computer not reading USB port
usb drive get faulty. replace it.
Posted on Oct 14, 2008
  • 24 Answers
SOURCE: How to recover data from a seemingly dead/non-functional USB flash drive
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
ericb@lc-tech.com
1-866-603-2195 ext 103
LC Technology International
Posted on Jun 25, 2009
SANDISK 32GB USB FLASH DRIVE
Things to try: -
1. Look in Control Panel/Computer Management/Storage/Disk Management and see if it appears. Check the drive letter if not there changer it.
2. Unplug any eternal drives and then plug the disk in. I have experienced where the drive letter is reserved.
3. Try it in another computer particularly one that has an inbuilt reader.
4. If this fails download Testdisk and see if it recognised. You can fix boot sectors and bad sectors with this.
Sep 06, 2017 | SanDisk Lot Of 5 32g 32gb Cruzer 2.0 Usb...
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When I plug in my flash drive, my computer won't read it. The light on the flash drive does not light up. Is there any way I can fix this?
Try it on another computer. If it works, then your computer's USB port has problem. Check the ports and make sure they are properly connected and are cleaned. Also make sure the USB driver is updated/installed. You can also try it on another USB Port of your computer. If it doesn't work on another computer, then I would say your Flashdrive is bad or gone.
Let me know if you need further help.
If you find this helpful, please take few seconds to rate the solution by hitting the 4 thumbs. If you can spare few minutes, you can even leave a testimonial to express your feelings about the solution.
Good Luck.
Thanks for using FixYa.
Feb 15, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Please can you send me detailed instructions on how to use a kingston usb memory stick
The memory stick becomes another drive, when plugged into the USB port. Some sticks have a write protect, which is a teeny tiny switch. If the switch is in the protect position, you can read but not write any data to the drive. Often the drive will be listed after all of your camera card ports.
To view the drive press and hold the Windows key and press the letter E. and then release both. The available drives should show up there.
Nov 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
Flash drive not lighting up and not being read
Hello aaron_s_robe,
Sounds like the flash drive may be faulty. You may try plugging it into another USB port on your computer, if that doesnt help try plugging it into another computers USB port.
If after trying the above doesnt work. Your drive is most likely bad.
Sep 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
I bent the insert on the drive and it work?
I would first try it in a different computer. If it does not work on the other computer it is unlikely it would work anywhere. It is possible you can take it to a local computer tech service and they can try and read or fix it, but I would think it is unlikely.
If it does work on the other computer I would inspect the USB port for damage on your computer. Or the place where you plug in the flash drive into the computer, if it looks at all damaged, I would contact the manufacture for repair. You can also try other usb devices to check if it still works.
As well if the flash drive does work on other computers, and there is no visible damage to the USB port, or plug in spot, then there may be a driver or software issue on your computer.
Apr 24, 2009 | Computers & Internet
Dane-Elec DaneElec 2GB USB Drive Red Hard Drive Logo
886 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
woodzowl307
pankaj rautela
pankaj rautela
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
