Hi there. Remove the laptop battery and the AC power supply, open the lid as far back as you can take it. Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away. Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it. To re-assemble just follow my direction in reverse. Please post back with the results and for any additional advice if needed.
The links below should help you start off w/ a price comparison to replace the keyboard for your notebook. Also included are the removal instructions. Hope this helps.
Connected A300 Satellite to HDMI TV worked perfectly. Watched movie using VLC. Can't get it to work...
(More)
Connected A300 Satellite to HDMI TV worked perfectly. Watched movie using VLC. Can't get it to work again. Tried HDMI Control and says only with tv that supports HDMI. TV is definately HDMI.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
