Question about Whirlpool GEW9250 Electric Dryer
No heat out of dryer
My dryer runs just fine but there is no heat!
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    your dryer has highlimit switches and a thermal fuse If you think you can do it safely I will help you but the cover must come off and, you must be careful because the machine must be turned on with the cover off
    President:
  • 1,136 Answers
HI, I just replaced an element in this model this morning. Remove the two screws holding front lower pane. The element is in a housing under the drum (right side). Check voltage to the two terminals while dryer is running and you should get 240V. If there is no voltage, you need to test the continuity of the thermostasts and safety on the blower housing (With dryer unplugged)
If there is voltage to the element, the element will need replaced. Part# 3387747. I have them on sale on my web site for $31.95 @ www.whirlpoolpartssurplus.com
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 22, 2009
  • Victor
    Victor May 22, 2009
    I am sorry. I have the part for $51.99 on my site.
    Vic
It's running fine but not heating at all on any
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101--==-
Aug 04, 2011 | Whirlpool Dryers
Dryer runs fine but no heat, igniter visably looks fine.
heatman101
Jun 26, 2011 | GE Dryers
My dryer runs fine, just wont heat, was working fine this morning, but on my second load of the day it stopped heating, cleaned all the lint from front-even pulled out and cleaned the lint from the back...
heatman101
Apr 30, 2011 | Bosch Nexxt 500 Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
90 series will not stay running or heat
DO NOT KEEP THE BUTTON PUSHED IN AND RUN IT...It's the motor relay and the even heat board in the console. By keeping the button in, you're bypasssing a safety feature and could cause fire. It won't heat like that anyway. Repl. the relay witht the small blue wires and the board in the console and you should be fine.
Jan 30, 2009 | Kenmore 659 Electric Dryer
I just moved and my LG dryer does not heat up.
Your ignitor (glow bar) got broken during the move. They are more fragile than your grandmother's fine china
Dec 16, 2008 | LG DLG9588 Dryer
Runs fine just no heat.
the heating element is out, or it has overheated and burned the wiring that runs to it
Mar 07, 2008 | Roper RES7648E Dryer
Whirlpool GEW9250 Electric Dryer Logo
104 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
