Question about Volfenhag ZX-4812 Car Subwoofer
Zx-8400 amp too much for zx-4812?
Just wondering if the zx-8400 amp is putting too much power to my zx-4812 sub, I have it bridged, it hits great, but every once in awhile it will make a pop sound, frequency is set to full and amp is all the way down on power, I dont know if it's just the box, because it has air leaks right now, or if its the sub..it doesn't do it all the time, and only does it on low notes, but yet never did it before with my 1200 watt amp...I'm thinking its the box, because when I look at the sub, when it makes that pop sound, it doesnt look like it's bottoming out or anything.
    Novelist:
  • 150 Answers
The amp and sub combo should work fine the subs can really take a crapload of power-i have a neighbor thats running 1200 watts rms to each sub in his caddy and OMG- its sick. Your amp should be pushing around 800 watts rms(continous) to the sub which should do very well-my concern with your setup is that the sub is designed for a vented box- you can use any box u want but im just suggesting that you use a good solid vented box with these subs- my other concern with your setup is that having only the single sub if its a dual coil 4ohm + 4ohm coils then you might run into trouble if you dont have it set up right-by that meaning to get all the power handling capability of the sub you would want to use both of the coils right? well to do that you have to either wire the coils in series or wire the coils in parallel right? In series the coils will yield an 8 ohm load to the amp and youll only get about 400 watts from the amp bridged into that 8 ohm load- on the other side of that if you wire the coils in parallel then the cols yield a 2 ohm load and that could cause the amplifier to become unstable and fry its little guts. All of this is assuming that the amp is made to run bridged at 4 ohms- if it is 2 ohm stable in bridged mode than you have nothing to worry about. Now the popping noise- that sounds like its coming from the amp somehow and just feeding through to the sub-like you ive never heard a sub popping unless its bottoming out and you say its not so its gotta be the amp id say-if it were me id check all power connections especially the ground for the amp . It could be that on the heavy bass notes that your amp is not getting enough juice -throw a 3.5 farad capacitor on the power line and see if that helps your system out-
Posted on May 23, 2009
What speakers I can wire to my amp? a volfenhag zx-8200 1000 watt amp. Currently 800 watt bose sub bridged to it, capacitor as well. and a 150amp circuit breaker. I have a 14 volt 105 amp alternator.
1. It depends on how many and what type of speakers you run.
It is a 'bridgeable' amp and therefore has a variable number of configurations.
You can run that Bose sub on one channel and twin up. It's not a great idea to have the drivers max near or lower than the output of the amp and puts out serious thump from a 30W cone.
Jan 15, 2017 | AMP Car Audio & Video
How do i remove the red ring protecting the screws from the sub so i can put it in a new box?
oh its just a rubber ring you just use you fingertips and peel it back one screw at a time. use a power screwdriver or a cordless drill and your fingers wont get as tired cuz its tough stuff-
Dec 11, 2010 | Volfenhag ZX-4812 Car Subwoofer
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Sub box dimentions
12 " subs need 1.5 cubic feet sealed box...
Jul 17, 2009 | Volfenhag ZX-4812 Car Subwoofer
Is my amp powerful enuff for woofer
That amp should work fine for that sub, but you should make sure that the amp has a good power system going to it, and the box for your sub is the right one. Either one of those things could cause problems if not done correctly.
-Dynami
Apr 02, 2009 | Volfenhag ZX-4812 Car Subwoofer
Subs not working but power to amp and cap are
when u press down on the cone do u here the speakers if u do and u have to let go off the cone and you dont hear noting just some bass im tinking ur subs are burn out(they dont work)
Feb 18, 2009 | Volfenhag ZX-4812 Car Subwoofer
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Bridging issues
There's no signal on the L- and R+ terminals.
If you're going to bridge both speakers on the amp, each speaker must have an impedance of 8 ohms (or more). If you're unsure of the impedance of the speakers, connect one speaker to each channel.
Let me know if you have any other questions.
Sep 19, 2008 | Kenwood KAC-6202 Car Audio Amplifier
Volfenhag zx-8400 amp and ZX-4712DVX subs
First of what you have should work great together....now the next thing is: does the bose system carry powered speakers if so the spliced speaker wires should be put onto a converter(a small box with RCA outputs) then you should make sure the levels in the little box is not set to full but 75%, if set to full you can be looking at distortion. Then they should set the amps to full range and see what you get.........oh and by the way you don't have to use that little controller(with the telephone wire) for the bass. You can control the bass with the frequency controllers on the amp or your head unit. And it's not a german thing trust me they come with nearly all amps now. These guys are full of ****. If you don't get the punch you want they should try bridging the amp for more of a punchy sound. Oh and you can use that decent sized box with the vent holes......that should work fine.
Jun 15, 2008 | Volfenhag Car Audio & Video
How to
First of all, make sure your amp is bridgeable. There are a few ways to bridge subs. series: hook one wire from the negative on the left amp output (or whichever is labeled on amp for bridged)to left sub negative. left sub positive to right sub negative, then right sub positive to the amp positive output.(like a big loop through both speakers) parallel: both speakers get their own set of wires, both negatives go to the bridge negative terminal, and both positives go to the positive bridge terminal. Series-parallel: A combination of the two. say two speakers in series, and one hooked up alone, but all to the same amp outputs. Bridging your amp/speakers basically lowers the resistance of the circuit and makes more current flow, more power, louder, harder hit. In series, it also makes both speakers do exactly the same thing, instead of "stereo sound" or L/R differences. What you're probably looking to do is Bridge in parallel. That will drop the resistance of the circuit the lowest, allow the amp to put out the most amount of current to the speakers, and allow your bass to hit the hardest. If your amp only has one output, hook up the same way as above. Just see what resistance your amp is stable down to. If down to 1 ohm, no worries. if stable only to 2 or 4 ohms, you may want to bridge in series to be safe. That will cause the resistance to go up, and will not pull as much current through the amp. The whole time, just remember Bridgeing and higher current mean HEAT so watch your amp. I hope this helped.
Oct 31, 2007 | Pioneer TS-W301R Car Subwoofer
Volfenhag ZX-4812 Car Subwoofer Logo
150 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
