Question about Ricoh Aficio CL7200 Laser Printer
Sc 542 error code
My ricoh aficio 2015 copier displays sc:542 error message on the screen. how do I resolve this fault? My 7200 has the same error message, but the menu is different. How do I fix this?
    New Friend:
  • 10 Answers
Press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
Posted on Sep 19, 2009
  • 183 Answers
You need to remove the fusing unit from the machine and open it inside has an termistor which is touching the surface of the teflon upper fuser roller. Try it with instrument dose the termistor is ok, it might be damaged or has attached dirt ot he surface so clean it
Posted on Jul 17, 2009
  • OfficeServiceAjnc
    OfficeServiceAjnc Jul 17, 2009
    Open the fusing unit and see dose the Termistor is OK it might be dirty or damaged, the SC code can be reset by entering the service menu and shut down the machine and turn it again.
    For to enter the service menu follow the next procedure:
    1. Press the (yellow key) [clear modes]
    2. Type the keys as follows: " 1 → 0 → 7 "
    3. Press the (red key) key [Clear / Stop]
    and hold it down until the SP-mode menu is displayed (about 3 seconds).
    4.Than Turn OFF the machine and again after 3 seconds turn it ON.
    That will reset the SC code 542 only if there has no problem with the termistor.
    PLEASE RATE ME IF THIS HELP YOU
  • MR Janjua Feb 14, 2011
    I can't find Yellow Key "Clear modes" on control panel
    please reply me the view of control panel with key assign
    regard MR Janjua
  • 114 Answers
542 A Fusing temperature warm-up error (center) The fusing temperature rises less than 7 degrees in 2 seconds, and this continues 5 times consecutively. The fusing temperature is not detected in 25 or 35 seconds. • Fusing thermistor defective or out of position • Fusing lamp open • Power supply board defective
Posted on Mar 19, 2010
  • 24 Answers
SC 542 is for fusing unit, touch yellow/clear key then press 1 0 7 and hold down "Stop" key for 10 second. LCD screen will change, turn off the machine from the main switch (not the top panel switch) wait for five second turn it ON. If code comes back then you need a thermistor or a fuse.
regards
Posted on Jul 07, 2009
    Problem Solver:
  • 5 Answers
You have to replace the termistor
Posted on Jun 17, 2009
  • 162 Answers
The fusing temperature does not reach
80°C within 30 seconds after the main
switch is turned on.
• Fusing thermistor defective or out of position.
• Fusing lamp open.
• Fusing thermostat open.
• Fusing thermofuse open.
• Power supply board defective.
Review all the item
Posted on Aug 31, 2009
  • 29 Answers
The 542 is a fusing thermistor error code.
Basically, there is a little thermistor in the hot section of the machine what senses how hot the machine gets too. Sometimes toner particals can get clogged up on the thermistor. Luckily though, this error can be reset on almost all ricoh machines.
Simply press,
(yellow clear), (1), (0), (7), (red stop * 5secs)
Make sure you hold the red stop button for 5 seconds, and make sure you enter this code while you are in copy mode.
Your screen will change, showing a few different SP modes,
Hold the hash button, and choose Copy SP
The screen will change once more, at this point simply turn the machine of at the main power.
This will reset your error code =] If the code decides to come back again it might be a good idea to get the machine checked out by a certified ricoh rep.
ta!
Posted on Aug 21, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How to reset the fuser error ( error code sc 542) in ricoh 1400
press yellow cancel and 107 and hold on 5 sconds on red cancel and yo will see 1 go to 4 and select 810 and press 1 simultanously with photo press you will see reset accepted or succes
Mar 25, 2011 | Ricoh Aficio 2015 Copier
The serial no is M0965802358 and the error message is SC542. Help
the SC-542 means your machine thermistor open please change it -thanks
Dec 08, 2010 | Ricoh Aficio 2015 Copier
Sc:542 error message on the screen
You need a firmware update…
SC542 SP1-103-2 Off + Temp has been newly added to prevent SC542 from occurring at machine power-on under low-temperature conditions.
Note: For this fix, it is necessary to use Controller firmware ver5.15.1 or newer.
Apr 02, 2010 | Ricoh Aficio 2015 Copier
I turn on my ricoh aficio 2015 this code SC:542 apear
itS THE TEMPERATURE OR FUSER RELATED ERROR.
try to clear it in service mode
Nov 30, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio CL7200 Laser Printer Logo
1,985 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
