Question about Dell Dimension 4600 PC Desktop
Computer won't shut off (occasionally)
My Dell Dimension 4600 occasionally refuses to shut off. It makes grinding sounds and I have to turn off all power to the machine. Even when I turn the power back on the grinding is still going and I have to hold the power button in to make it stop.
  • nan2ksja May 25, 2009
    The noise seems to be coming from the CD CD/RW drive.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Is the grinding sound coming from the hard drive?
    Genius:
  • 1,605 Answers
Usually this the indication of Hard driver problem.
this hard drve is on its last lag. it is hardware failure.
get a new Hard Drive and copy everything to the new hard drive. save this one as a backup.
Posted on May 22, 2009
Dimension 4600 dvd drive keeps opening
Try this first - open up the BIOS part of the system. To do this, shut the computer off; wait at least 10 seconds; turn the computer back on and then press F2 when the Dell logo appears. Press continually until the message Entering Setup appears. In the Boot Order section, remove the CD/DVD drive from the boot order by clicking on Disable from the drop-down menu. If this doesn't fix it, please resubmit your question
Feb 19, 2015 | Dell Dimension 4600 PC Desktop
Dimension 4600 no display turn on. HD spins lights lite and can turn off no bios screen display
Change the VGA cable from the monitor, first but sounds like it's the video card that's failed. I would check the monitor with another computer to make sure it's not that.
Jun 03, 2014 | Dell Dimension 4600 PC Desktop
Dell 4600 won't power up following lightning storm. PSU and power button both test OK. Suggestions please! many thanks
Check everything between the power supply and the wall outlet. If everything else is working using the same power a part of your computer is fried.
Jul 27, 2011 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 won't boot up and when you try to turn it off with the button it just starts back up.
It sounds like a back-up was started and now your system is trying to complete the task before it shuts down. You can turn it off by holding the power button down for 10 seconds. This will cause the power supply to shut down completely. You will lose any unsaved data and it may corrupt your back-up.
Mar 25, 2010 | Dell Dimension 4600 PC Desktop
Card fan makes noise
Turn off your computer, if your familiar on how to open-up you CPU do so, then,
Try cleaning the fan.
What you can do is clean it with a bush (ex. paint brush-a clean one) or a clean cloth.
you can also try to remove the fan then at the center of the fan there's a sticker, you can safely peel it off then you will see the center of the fan, you can apply machine oil on it, then put the sticker back. Then turn on your computer, let's see if you still has the problem :)
Mar 01, 2010 | Dell Dimension 4600 PC Desktop
Soundcard for dell 4600
There are 4 different versions sound card drivers for this Dell Dimension model (4600).
Go to 4600 and select Audio then download which version from the list for your desktop.
Till next time, take care of your desktop.
Feb 07, 2010 | Dell Dimension 4600 PC Desktop
System recovery dell dimension 4600
you need to press the
ctrl + F11 as soon as you see the Dell logo screen when you turn on the computer.
the trick is. as soon as you turn on the computer, press and hold on the ctrl key then keep tapping the F11 key.
Sep 30, 2009 | Dell Dimension 4600 PC Desktop
No sound
You should see if you could download the latest drivers for the sound card, this might fix your issue. You can download the drivers for your Dell model here --> http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=. Also there appears to be a patch available, however it might not apply to your audio card. Make sure that you know the manufacturer of the audio card, which can find by going to Start --> Run --> type in "control" (w/out quotes) and then press enter. Click on Sounds and Audio devices and then you should see who the manufacturer is. Hope that this helps
Serge
Mar 30, 2009 | Dell Dimension 4600 PC Desktop
Dell 4600 Dimension Computer
are you getting the DELL logo screen.
Jul 04, 2008 | Dell Dimension 4600 PC Desktop
Hard drive and cd drives still on
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dec 09, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
