Question about Sharp XR-11XC Multimedia Projector
Projector will not turn on. No lights no nothing
My projector just stopped turning on all of a sudden. No lights no nothing. Tried different power cords tried different outlets, nothing. Sharp wants 225.00 to look at it. Any thoughts?
  • 3 Answers
I opened mine up and in th front was a red reset button now I'm good!
Posted on Apr 19, 2010
  • 1,906 Answers
Replace the fuse in the power supply it is marked with a label
Posted on May 22, 2009
Suddenly turn off blue screen
The problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so, you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Nov 16, 2013 | Sanyo PLC-XL51 Projector
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
When I using my Acer X1160z projector, the projector suddenly shot down and never turn on again. What is the solution for this problem?
Have you tried changing the power cord? Has it been damaged or fried?Has the internal onboard fuse blown?check the lamp and dust filter and that everything looks how it should and clean and normal.
Dec 18, 2009 | Acer X1160Z Projector
Just turned projector on - lights are flashing and nothing is working... can it be reset??
which lights? could be the lamp has expired, the colorwheel stopped spinning, the ballast/power supply had burned out, or the fans have stopped. if it's the lamp light, replace the lamp.
Nov 01, 2009 | Optoma MovieTime Digital DVD Multimedia...
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Dec 30, 2007 | InFocus Play Big IN76 Multimedia Projector
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
1,235 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
