Question about HP Color Inkjet cp1700ps Printer
HP 1700cp - Can only print with Rear Manual Feed and Not Tray 1
I can no longer print using Tray One but can with the Rear Manual Feed. The Obvious problem is that I have to put each sheet in individually and doesn't make sense time-wise. Is there something I can trouble shoot to make the printer accept paper form Tray One?
Thank you in advance,
Joe
  • jhaskett600 May 22, 2009
    Thanks frcs68,
    the printer does not pick up the paper from tray 1.
    How does one 'check the roller?'
    The default is set to Tray 1.
    thanks again!
    Genius:
  • 1,605 Answers
Does the printer pickup the paper from tray 1?
if not check the roller, it may time for replacement.
2- make sure the computer program is set at autofeed as default.
or tray 1 as default.
Posted on May 22, 2009
  • Frank
    Frank May 22, 2009
    in that case the pick up roller need to be changed.
    search the Internet for HP 1700 printer repair kit.
    there are few company supply the repair kit, basically you need to take the printer apart, if you don't want to do that, then you can find a HP repair shop near you and have them change it. price may not warrant the repair.
Won't print manual feed
MANUAL PRINT IS ALSO KNOWN AS TRAY 1 ON HP PRINTERS. LOAD PAPER INTO THE SLOT ABOVE YOUR PAPER TRAY.
Dec 13, 2015 | HP LASERJET P1006 Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Mar 18, 2011 | HP LaserJet P4015 Printer
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
HP Color Inkjet cp1700ps Printer Logo
137 people viewed this question
Seeker5211
Seeker5211
