Question about D-Link Vonage-enabled Wireless Router (VWR-VR)
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
I have a D-Link Vonage Wireless Router. I get internet perfectly fine on wireless but I cant get internet hardwired(Ethernet). And it keeps on telling me This compueter - Undentified network - x- internet.. does anyone know what the problme is??
  • fatassonlose May 22, 2009
    Well i've look through my settings to figure out what is wrong. but i cannot figure it out...can you helkp me out?/
    Problem Solver:
  • 14 Answers
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
Posted on Jul 03, 2009
    President:
  • 1,383 Answers
There is problem with youtr router internet settings set correct settings in router,
u can acces your router with following link
http://192.168.1.1
or 192.168.0.1
type usename as "admin" and password also "admin" or blank
Posted on May 22, 2009
  • 1 more comment
  • kishor
    kishor May 22, 2009
    first check your ethernet cable service provider and get ip adress for settigns in router
    call them
  • kishor
    kishor May 27, 2009
    pls sir rate my solution as thanks for trying if u think that i give u technial solution
  • kishor
    kishor Jul 15, 2009
    Sir can please rate my solution as Thanks for try?
I have an unidentified network in my Network and Sharing Center, it will not let me change it to my wireless network name. I can not connect to the internet. how do I fix this?
Manually select Static IP.
First scan for valid gateway ip
Use as a gateway for your wifi
and get internet access..
if u cant get,it is cause of No valid internet access,just they are playing for Network local game :))
Jun 24, 2014 | TP-LINK (TL-WN822N) Pre-802.11n Wireless...
I just got a NETGEAR n600 dual band router, ran the resource cd to set up the network, and everything was successful. Whenever i connect to the wireless network my computer says its connected to an...
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Dec 09, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Hi i am trying to access my home wireless network using my laptop. I get authentication error. I can connect to my home network by it says it is Unidentified Network for one and then it does not connect to...
you will be havin a wep or wpa security for wireless connection..type in that correctly..if u had forgotten it then connect ur laptop hardwire to ur router and configure router setting...type in 192.168.1.1 in ur browser address bar..ur router page will open..generally, by default password for router page will be "admin" or "password".. username will be "admin"...if u hav any issues then get back to me..
Jun 11, 2010 | Intel PRO/Wireless 3945ABG Network...
WIRELESS PROBLEMS
Well it should work on all the computers.
There might be some problem with the wireless connection.
You said the wireless works on all the other computers . that means the wireless router is working fine.
If your wireless network is secured then make sure that you have the correct network key / password.
Check the IP address on your wireless computer . Is there any static IP address on the computer.
Click Here
for step by step instructions
Mar 09, 2010 | NetGear WGU624 Router
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Cant get wireless internet to work
First, check to see if there is a button on the keyboard that looks like an antenna. It usually hasF a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections
Click window opens. Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 28, 2008 | Computers & Internet
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
Linksys wireless connection keeps getting dropped
From you DSL modem or broadband router, what is the next device connected?
Nov 27, 2007 | Linksys Wireless-G WRT54GS Router...
D-Link Vonage-enabled Wireless Router (VWR-VR) Logo
1,429 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
