Question about Garmin nuvi 200W GPS Receiver
My reset button is covered with a plastic piece, under a sticker
My nuvi 200 is acting up and I want to reset it. I located the place the reset button should be, but there is a long sticker with numbers and letters on it. I lifted the sticker a little and the area is then covered with a square plastic piece, attached only on one side. I don't see anywhere that this should be broken off before resetting. Do I need to removed the whole sticker to see the button?
Thanks in advance for any help. Nuvi has failed me 2 out of 3 trips!!
  • joanl205 May 25, 2009
    Thanks for the fast response. I have found that the problem is deeper then I first thought. The battery life is only lasting about 2 hours, when it switches to the car charger, it blows the fuse in the car charger. Mechanic told me my car isn't able to handle the extra power strain. If I start out on car cable power, the fuse blows almost immediatly. I have a Dodge Caliber. I just have to go short trips??
    Thanks again for your help, Jim.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    The plastic tab is designed to be pushed in with the tip of a ball point pen. The tab then presses the reset switch on the board. You don't need to pull up the decal to reset the unit.
    - Jim
    SHARCNET-USA
  • 48 Answers
The reset button should be located under the faceplate. Stick your thumb nail under the Garmin name and pop the faceplate off.
Posted on Jun 02, 2009
System software missing gps garmin nuvi 255w
Have you tried a hard reset? There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Jun 12, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi 255w freezes on garmin loading maps screen how do i get working again
Did you try a reset. There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. It will clear out all you favorites etc.. so copy them first if needed. Gently push the reset and it will reboot and ask to confirm and choose yes. See if this works
I will attach Garmins contact info. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Add a comment
May 05, 2011 | Garmin nuvi 255W GPS Receiver
Garmin NUVI 260 W's reset switch is NOT located as indicated. Where or how is it reset? There is no circle or dot anywhere on the device.
Some of the older Nuvi 200 series will have a reset buttonon the bottom of the device. It can be found on the bottom of the device on thesame sticker that the serial number is printed on. It is a very tiny button andhard to see. So look carefully!!I have one on mine and swear it's almost impossible to find! - Poor design I say...
Jan 14, 2011 | Garmin nuvi 260W GPS Receiver
My Garmin Nuvi is frozen, How do I reset it?
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker.You get to the "Do you really want to erase all user data?" message.
Nov 21, 2010 | Garmin nuvi 255W GPS Receiver
Nuvi® 255W Car GPS Receiver: My garmin 255w froze. Where is the reset button....
On the bottom of the Garmin 255W is a long sticker...with a Icon that says reset...peel the sticker back and under it you will find a break away tab...the reset button is under there..
May 17, 2010 | Garmin nuvi 255W GPS Receiver
Where is the reset button on a nuvi? a tiny screw-like thing?
the reset is on the bottom of the GPS, it is covered with a decal labled "reset", use a straightened paper clip to depress the recessed reset button.
Feb 10, 2010 | GPS
My nuvi 205 garmin stops working s soon as I
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First Make sure your plug and power cord are working. USE a Garmin charger!!!!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
Nov 01, 2009 | Garmin nuvi 205 GPS Receiver
I have a Nuvi 260. Where is the reset button? The manual that came with the unit is for a 200. Is the button under the sticker somewhere?
It hard to see, not hard to find....look CAREFULLY
Might need glasses to see it depending on your age!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Jun 06, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260
What you would do is, under where the model code sticker is under is the reset button. remove the sticker and hold down the reset button for 10 seconds at the same time hold the power button towards the left.
May 14, 2009 | Garmin nuvi 260W GPS Receiver
Just got the garmin nuvi 260w today and plug in car and will not power up?
RE: Garmin Nuvi 260W Grrrrrr...I could not get my new GPS to turn on straight out of the box, even after charging it in my car for hours. I watched the on-line video - but could not find the reset button (different location than what was on the video). I finally thought I couldn't reck anything worse so pressed the tiny reset (sticker) - not button with my fingernail so hard I practically went through the sticker - and that worked.
Quick Start Manual should state SOMEWHERE that your unit might have to be reset before being able to be powered on. Clarify that it is a button hidden under the sticker in really small print. This was very frustrating.
BUT - Once I figured it out - it was so easy to work - I was impressed!
Sep 30, 2008 | GPS
Garmin nuvi 200W GPS Receiver Logo
299 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
