Question about IBM Infoprint 1634 Laser Printer
Infoprint 1634 repeatedly jams
My Infoprint 1634 repeatedly jams in the fuser unit. The paper clears the exit rollers by about a 1/4 inch then stops. I cleaned the rollers but the printer continues to jam.
  • 3 more comments
  • betht991 May 22, 2009
    Yes the exit rollers are running.
    I am now getting a "Service Engine Self Test" error as well. The Fuser has 70% life remaining.
    I ordered a new fuser unit. Thanks!
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats "Service Engine Self Test" error " message?
  • Frank Zhang
    are you sure the exit rollers running when the paper comes
  • 326 Answers
It may be time to replace the Fuser.
There is no certified way to repair a Fuser with purchasable parts, the assembly it self must be replaced.
Posted on May 22, 2009
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
We can not clear the paper jam error. We have cleared the paper jam, turned the unit on and off, unplugged the unit, moved all the rollers, can not see any pieces of paper that are still in the misfeed but...
This copier has 4 sensor
1. paper sensor
It is called paper sensor its installed paper tray
2.Drawer sensor
3. Drive sensor its installed middle position
4. Exit sensor it is in fuser unite.
May be any sensor displace or broken.So you should check it.
Good luck.
Feb 16, 2011 | Sharp AL 1631 Copier
What is this ??
Typically there is a piece of paper caught in the fuser exit. If no paper evident(ie paper feeds cleanly, stops 1 inch past fuser) verify there are 2 sensor exit flags present and free to move. Occasionally 1 of the flags gets broken off the sensor causing this jam.
Jan 27, 2010 | IBM Infoprint 1332 Laser Printer
Paper jam in fuser
Sounds like a timing jam, check paper supply, fanned, good quality, check and clean paper feed rollers.
Registration rollers clean?
If you are a tech, check and clean paper feed clutches, registration clutch. Check fuser for bearings, fuser drive, fuser roller cleaner or worn rollers.
Check exit sensor, is it out of place, is the actuator worn out, is the paper curling and coming off of the paper too early,
Try these, hope it is of some help.
Ed
Apr 23, 2009 | Office Equipment & Supplies
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Prnter jam
check in the fuser unit.
Feb 16, 2009 | Lexmark T630 Laser Printer
How to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Dec 21, 2008 | HP Color LaserJet 2600n Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
IBM Infoprint 1634 Laser Printer Logo
144 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
