Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Plastic covering my door was installed one year ago the installer did not remove the protective plastic on the door panels. How to remove now? I have tried and the plastc just tears into small pieces any help thanks mq
    Genius:
  • 1,605 Answers
Get some wide tape like packaging tape and tape the plastic. start from one end and pull on the tape, the plastic should come off with the tape. then you can clean up the small peices.
Posted on May 22, 2009
Replace the door lock switch on 2009 lincoln towncar
Use pry bars to remove door panel. Remove screws on door panel look for hidden screws behind small plastic covers. Then disconnect switch and install new one
Mar 26, 2014 | Vehicle Parts & Accessories
How do you remove the inside door panel backseat right side of a mercury grand marque 1996
Door Panels REMOVAL & INSTALLATION 1989–91 Vehicles
  1. Disconnect the negative battery cable.
  2. On 1990–91 vehicles, remove the speaker grille.
  3. Remove the retaining screws from the door inside handle cup.
  4. If equipped with armrest courtesy lamps, remove the lens, detach the bulb and wiring assembly from the pull cup and remove the pull cup.
  5. Working through the pull cup opening, disconnect the remote lock rod from the lock knob.
  6. Remove the retaining screw and the remote mirror bezel nut from the power window regulator housing switch plate, if equipped.
  7. Raise the plate to expose the window switch and power door lock switch and disconnect the switches.
  8. Remove the retaining screws from the armrest finish panel.
  9. Remove the retaining screws from the armrest and remove the armrest.
  10. Using a suitable trim pad removal tool, carefully pry the trim panel plastic push pin retainers from the door inner panel. NOTE: Do not use the trim panel to pry the clips from the door inner panel. Replace any bent, damaged or missing push pins.
  11. Disconnect the radio speaker wiring, if equipped.
  12. Remove the trim panel and watershield. To install:
  13. If the door panel is to be replaced, transfer the plastic push pins to the new panel. Make sure that the watershield is positioned correctly to the door sheet metal. Remove the door pull handle from the old panel and transfer to the new one.
  14. Position the door panel loosely to the door belt opening and route the wiring harness through the appropriate access holes in the panel.
  15. Connect the radio speaker, if equipped.
  16. Align the plastic push pins on the door panel to the holes in the door sheet metal and press the pins into place.
  17. Install the armrest and route the window regulator, remote mirror cable and power lock harness through the access hole.
  18. Install the armrest finish panel.
  19. Install the power window regulator switch plate housing to the armrest connecting the power window switch, power door lock switch and remote mirror bezel nut, if equipped, prior to securing the retainer screw.
  20. Connect the lock remote rod to the lock knob retainer boss. NOTE: Make sure that the remote rod is fully seated into the retainer boss, then function manually or with the power switch to ensure smooth operation of the lock knob.
  21. Install the bulb and wiring assembly.
  22. Install the lamp lens, if equipped, and the pull cup.
  23. On 1990–91 vehicles, install the speaker grille.
  24. Connect the negative battery cable. Fig. 1: Front door panel — 1990–91 vehicles 84170064.gif
    Fig. 2: Rear door panel — 1989–91 vehicles 84170065.gif
1992–98 Vehicles
  2. If removing the driver's door panel, remove the nut from the outside rearview mirror control switch.
  3. Remove the window regulator switch housing by gently prying up, starting at the front. Fig. 3: Front door panel — 1992–98 vehicles 84170066.gif
    Fig. 4: Rear door panel — 1992–98 vehicles 84170067.gif
    Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front 89600p08.jpg
  4. Detach all connectors from the switch housing.
  5. Remove the door inside handle cup.
  6. Remove the push pin from the door trim panel upper front extension and remove the screw.
  7. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel. Fig. 6: Detach the switch housing electrical connector and remove the housing 89600p09.jpg
    Fig. 7: Remove the door inside handle cup 89600p01.jpg
    Fig. 8: Remove the screws from the door panel in the front and on the upper extension 89600p02.jpg
  8. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  9. Lift the door panel upward and snap out the panel. Fig. 9: There are also retaining screws located in the map pocket as well as . . . 89600p03.jpg
    Fig. 10: . . . along the bottom edge of the door panel 89600p04.jpg
  10. Disconnect the necessary wire harnesses and remove the panel. To install:
  11. Connect the wire harnesses to the door panel, as necessary.
  12. Install the door panel by pushing in and down until it snaps into place.
  13. Install all self-tapping screws retaining the door trim panel to the door inner panel.
  14. On Grand Marquis, install the door pull handle, tighten the screws and install the screw covers.
  15. Install the push pin covering screw on the panel upper front extension.
  16. Install the inside door handle cup.
  17. Install the window regulator switch housing and install the nut on the outside rearview mirror control switch, if removed.
  18. Connect the negative battery cable. Fig. 11: Lift the door panel upward and snap out the panel to remove it from the door 89600p05.jpg
    Fig. 12: Rotate the door marker lamp bulb and remove it from the door panel 89600p06.jpg
    Fig. 13: Detach the connectors for the trunklid and fuel door release switches 89600p11.jpg
    Fig. 14: Slide the relay connector off of the door panel and remove the door panel from the vehicle 89600p17.jpg
Aug 26, 2010 | Mercury Grand Marquis Cars & Trucks
Need to remove door panel. How?
Door Panels - REMOVAL & INSTALLATION
The many different design interiors make it impossible to list each fastener location. The trim panels that must be removed are held in place by screws and clips. These locations vary from model to model. After removal of all the fasteners that you are aware of, if the trim panel is still firmly attached, you probably missed a hidden fastener. If this happens, gently and carefully pry the area looking for the location that doesn't flex. The location that does flex is where you'll find the fastener(s) you missed. Screws and retainers are usually hidden. Handle trim, reflectors, light lenses and other plastic pieces usually cover the main retaining screws. Take great care with the plastic trim panels. Plastic trim panels are usually very hard plastic and extremely easy to crack. The following steps can be used to guide you through the removal and installation of the trim panels, but you may need to alter these steps to your specific needs.
  2. Pull the inside door handle to the open position, unfasten the screw and remove the handle escutcheon.
  3. If equipped with manual locks, remove door inside locking rod knob.
  4. If equipped with manual windows, insert a suitable window regulator handle removal tool behind the handle. Disengage the retainer, then remove the handle.
  5. If equipped with power windows and locks, use a small flat-bladed prytool to carefully pry the switch plate up, then detach the power component electrical connectors.
  6. If equipped, remove the screws inserted through door armrest and pull handle assembly into door inner panel or armrest hanger support bracket.
  7. Lift the seat belt trim panel up and remove the hidden retaining screws.
  8. Remove the outside side view mirror trim plate retaining screw. Lift the panel up to disengage the retaining clip, then remove the trim panel from the door.
  9. On styles with courtesy lamps located in the lower area of the trim panel, disconnect the wiring harness at the lamp assembly.
  10. If equipped, use a suitable tool to pry the reflector plate from the side of the door panel.Remove bottom trim cover retaining screws, then remove the lower trim cover.
  11. Remove any necessary electrical connector CPA clips, then unplug the electrical connectors.
  12. On styles with integral armrests, remove the screws inserted through the pull cup into the armrest hanger support.
  13. Unfasten the door trim panel retaining screws. The locations of the screws will vary depending upon the year of model of vehicle. The screws are usually hidden, so be sure to look carefully to make sure you don't miss any.After all of the trim panel retaining screws are removed, slide a suitable trim panel removal tool between the door panel and door perimeter to carefully disengage all of the trim panel retaining buttons. Make sure to position the tool close to the fastener, or the trim panel may be damaged.
  14. Carefully lift the trim panel away from the door, checking to be sure all of the retaining buttons and screws and electrical connectors are unfastened.
To install:
Before installing the door trim panel, check that all trim retainers are securely installed to the panel and are not damaged. Replace damaged retainers as required.
  1. Connect electrical components where present.
  2. To install the door trim panel, pull door inside handle inward; then position the trim panel to the inner panel, inserting the door handle through the panel hole.
  3. Position the trim panel to the door inner panel so that the trim retainers are aligned with the attaching holes in the panel, and tap the retainers into the holes with a clean rubber mallet. Install all previously removed items.
  4. Install the remaining door panel components in the reverse order of removal.
  5. After installation, connect the negative battery cable, then check for proper attachment and operation of electric components, if so equipped.
Hope helps (remember rated and comment this).
Jun 29, 2010 | 1987 Oldsmobile Delta 88
I need to know how to replace the driver side rear window.
You dont tell us excalty the year of your CRV, so keep in mind that this is the procedure for 2000 Honda Truck CR-V 4WD 2.0L MFI DOHC 4cyl, other year is similar process. If you need take off the window, you need take off the "window regulator", so check this...
Honda CRV/Odyssey 1995-2000 Repair Information
Door Glass and Regulator
REMOVAL & INSTALLATION CRV Models and 4-Cylinder Odyssey Models
(see Figures 1, 2, 3 and 4 )
Fig. 1: Always matchmark any fasteners that are mounted through a slotted hole. This bolt is used to adjust the window position
Fig. 2: The window is raised just enough to access the mounting bolts
Fig. 3: Once the window fasteners are loosened, the window can be tilted and lifted out of the door
Fig. 4: Slide the window motor/regulator assembly out of the door
  1. Remove the door panel, as outlined in this section.
  2. Remove the plastic vapor barrier.
  3. On 4-cylinder Odyssey models rear door glass, remove the center rear channel bolt and remove the channel.
  4. Carefully raise the door glass until the bolts are visible.
  5. On 4-cylinder Odyssey models rear door glass perform the following:
    1. Remove the self-tapping screws from the outer triangular trim cover and remove the cover.
    2. Remove the door glass bolts.
    3. Carefully lower the glass, then remove the bolts and nut from the rear lower guide channel.
    4. Remove the glass from the rear guide channel.
    5. Apply protective tape around the painted surfaces of the window sash trim.
    6. Tilt the window forward and remove from the window slot.
  6. Loosen the bolts, then slide the lower guide forward and remove the window from the guide.
  7. Carefully pull the glass out through the window slot. Take care to not drop the glass.
  8. To remove the regulator, perform the following:
    1. Scribe a line around the rear roller guide bolt to mark its original position.
    2. Disconnect the electrical connector and harness clip, then remove the regulator mounting bolts.
    3. Remove the regulator through the hole in the door.
  9. Installation is in reverse order of removal. Apply grease to the rollers, guides and sliding surfaces of the regulator. Make sure to install the roller guide with the rectangular hole facing rearward. Check the window operation before installing the door panel and adjust if necessary.
Hope helps.
Jun 12, 2010 | Honda CR-V Cars & Trucks
How do you remove interior door handle form 1993 Ford Tercer The window won't roll up and I can't get the handle off to get the panel off to get to the window tract
It's easy!
  1. Remove triangle-shaped plastic cover Fwd of door window - gently pry it off
  2. Remove screw from the plastic cover behind door open lever
  3. Remove door lock plunger. (unscrew)
  4. Remove screws down inside the door pull hand-hold area
  5. Look for other phillips screws - sometimes around the lower 1/2
  6. Pry hidden plastic hold down fasteners from around the edge - pull the panel away from the door and where you see it 'stuck' to the door, slide a pry tool, a stiff putty knife works well, up in that area and pop the fastener off.
  7. Lift door liner enough to get to the mirror power connector and unplug.
  8. For some model years, with door panel loose, you can access the bolts / screws that hold the interior trim piece in place and remove.
  9. Remove Mylar cover for access to 3 Mirror mount studs, speaker screws, door lock actuators, window motors, etc.
  10. Remove nuts, (hold the mirror up from outside) and remove mirror. (Feed electrical harness through door openings as required to facilitate removal.
  11. Reverse order for installation.
Jun 01, 2010 | 1993 Ford Taurus
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Installation
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
How to install a door handel left side on a dodge ram 1500
remove the door panel and peel back the plastic dust protection sheet then remove the door latch actuator rod at the door handle by pressing the plastic clip back to you and it will rotate to you and the rod will simply pull out of the handle then remove the two 10mm screws one on each side and the handle will come right out then just reverse procedure for installing the new one.It is actually a lot easier then it sounds,hope this helped
Jan 02, 2010 | 2005 Dodge Ram 1500
Anywhere to find a breakdown to change the door handle that broke off on a 94 pathfinder?
Very easy to do...I have a 1990 and they are interchangeable....88-94: Door Panel
  1. Fully lower the door glass.
  2. Remove the arm rest, door lock knob and inside door handle escutcheon.
  3. For vehicles with manual windows, remove the regulator handle which is retained by a spring clip.
  4. Gently pry the door panel away from the door.
Interior side and floor trim removal procedures-Pathfinder
Remove the lock button first before removing the door panel
Remove the plug to gain access to door panel retaining screws
Remove the trim cover
Remove the door handle trim
Remove the power window switch trim panel
After loosening the power window switch trim panel, disengage the electrical connection
Remove all the necessary trim panels before removing the door panel clips
View of the door panel retaining clip-clip must be installed in the hole straight
Make sure the watershield plastic is in place before installing the door panel
Installation is the reverse of removal.
Dec 10, 2009 | Nissan Pathfinder Cars & Trucks
Removing 2000 VW passat door panels for speaker install.
The door panel comes off With a T-10 torx or a Hex (Allen) wrench
that will fit and A large Philips Screw Driver..
Remove the Plastic cover on the inside Door handle.
And the Screw or Screw along the Bottom of the door panel.
Then remove the screws that hold the handle the the door.
They are located behind the Plastic plate you removed with a tiny screw driver earlier... Be careful not the mark up the cover whaytprying it up. It is best to pry from underneath. Where marks if made can not be seen
After the screws are out 4 I believe. The Use of a CLip tool ir best.
For getting behind the panel to pop it off. A screw driver will work.
After all the clips are released. Pull the light at the bottom of the panel down and out. Disconnect it ur push it back thought the hole it came from..
reverse to install
SKETCHLAB.com
Apr 23, 2009 | 2000 Volkswagen Passat 4Motion
How do you repair a gmc sierra 1998 inside door handle
You have to remove the door panel, if you have roll down windows the handle will have to be removed. After panel is removed you have to drill the one rivet that hols the interior handle. slide the handle down and unfasten the rod retaining clip. Please make sure you do not break the clip. Install the new interior door handle, clip and provided fasteners. Try the door before you install the interior door panel, Note the is a good time to lube the window roller and the door mechanism. Make sure to install the water shield to provide the protecting from the elements. Line all the plastic retaining clips and or replace if they are broken. Good Luck.
Jul 22, 2008 | GMC Sierra Cars & Trucks
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
51 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
