Question about Marshall Music
Marshall valvestate 8080 1. when i turn the buttons they make a cracking sound 2.when i play on it the sound becomes very quiet
I have a marshall valvestate 8080 and every time i turn it on the sound fades away and becomes very quiet. A second problem is that when i turn the buttons they make a lot of cracking sounds. Any suggestions ??
  • egonvanertve May 23, 2009
    thanks man, great answer
  • 5 Answers
As an electronics tech for 40 years I have spent half of those years reparing the damage done to electronic equipment by WD40. It is a great product when used in the correct situation. When it comes to cleaning controls in amplifiers etc the correct procedure is to apply a contact cleaner to flush out any dirt then apply a contact lubricant. WD40 contains minute graphite particles as well as corrosive chemicals. Between the two they swiftly render the controls to the bin.
WD40 great for unlocking rusty screws etc but never use it in electronic gear.
Posted on Jun 01, 2010
  • 585 Answers
The crackling, and the low volume could both stem from just the control problem. I suggest a cleaner such as Tech Spray 1677 in the controls first, just a 1/4-second spritz is all it takes into each resistor element, work the control limit to limit many times, and then a similar spritz of WD.
Posted on May 23, 2009
  • 73 Answers
When turning the knobs you might get a crackling noise if the amp is old, The knobs get worn. Either you can replace them or repair them with a tiny squirt of WD40. Check youtube videos for help.
As for the fading sound, That would be your valves ... They need to be replaced ... I suggest taking it to a repair dhop for that because they need to be matched.
  • 93 Answers
The noisy pots can be cleaned using contact cleaner specifically made for controls.As for the sound dying or being low:Jumper the power amp in jack to the preamp out jack [or effects send jack to the effects return jack]. There may only be oxidation in the contacts of these jacks. If the normal sound level comes back-either clean the two jacks or have them replaced.
Posted on Nov 23, 2014
MY Marshall JCM 2000 100Watt head is quiet TURNED fully on stand by OFF and ready to plug guitar into the INPUT Jack. Soon as I plug into the INPUT Jack cracking noise hissing noise.
I would suspect a bad cable. Also, these symptoms show up if you mistakenly use a speaker cable (unsheided) as a guitar cable (shielded).
Dec 12, 2016 | Marshall Music
Marshall repair valvestate 8080
if it is C1 then it's the input capacitor from the instrument jack input, it's value is 10nF, as to it's type it could be 1 of three and I don't know without seeing it although all would work, from cheapest to most expensive, they are :- mylar, polyester or polyester film.
Good luck.
Aug 17, 2014 | Marshall Amplification Music
Marshall troubleshoot
First check the preamp valve in that curcuit
Feb 26, 2014 | Marshall Amplification Music
When I plug my P803 2 Way footswitch into my Haze40 amp the effects light flashes and the footswitch will not change channels or effects.
The P803 is designed to work with the "Valvestate" and Tube amps. I don't think it is compatible with the Haze40 since they have an optional 4 button footswitch so the optional one would necessitate different interface than the P803.
Jun 02, 2011 | Marshall Amplification Marshall P803 2-Way...
Its a marshal 8080 valvestate 80 v and it buzzes and some of the knobs crackle when turned,
Buzzing could be normal for this amp, especially if you have the gain cranked way up (or the volume way up) see if the buzz goes away when you turn the gain/volume down. If not, there is a problem that needs to be properly diagnosed by the amp tech at your local music store. The crackling is also unfortunately rather normal for an amp that's a little older. Oxidation builds up inside the knobs and makes that noise as you turn them. If it only happens when you change settings I wouldn't worry about it, but if it gets bad, a tech guy can clean it out for you.
Feb 20, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall amp goes quiet
Often this is a broken input connector or an electronic failure such as a tube or semiconductor device.
On some units a failed switch on a jack for direct input to the power amp can cause this. Oxidation at the contacts causes this problem.
Apr 27, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
My marshall valvestate 100 will completly cut out when im playing and the only way to make it come back is to turn it off and then on. it makes a really loud pop when i have 2 preform this task
It sounds like one of the filter capacitors is getting ready to fail in the power supply. Here is a link to some good info:http://www.geofex.com/ampdbug/ampdebug.htm Here is the schematic:http://www.ampix.org/displayimage.php?album=31&pos=112 Let me know if this helps.
Nov 30, 2009 | Music
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Nov 05, 2009 | Marshall Amplification Marshall MG250DFX...
Music Logo
865 people viewed this question
Top Marshall Music Experts
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
