Question about Dishwashers
Hot water won't shut off
Hot water won't stop running. Have tried to unplug and replug washer. This sometimes works but problem quickly returns. We must turn off water supply to complete cycle.
  • gayle262 May 22, 2009
    It is the Kenmore Elite HE3t Front loading automatic washer (clothes)
    Complete model number is 110 45962401
  • 1,889 Answers
Your float switch is not working: there is a small round float located in the front bottom left (facing the door) area of your dishwasher this plastic float has a pin that goes into a hole on it's underside when the water reaches the top of the dishwasher tub it lifts up the float opening the switch under the pin shutting the water off
Posted on May 22, 2009
  • Jim Goldsmith
    Jim Goldsmith May 22, 2009
    My appologies! I mis-read your post
    President:
  • 1,136 Answers
Hi, The water inlet valve has gone bad. If I could get the model#, I will look up part# for you and tell you how to replace it.
Thanks
Vic
  • Victor
    Victor May 22, 2009
    Open the door and there should be a tag with complete model #
  • Victor
    Victor May 22, 2009
    Ok, Thanks.
    Part# 818169 and it appears to be located right under top panel. Unplug the washer. Remove the two fill hoses.Should be three screws on the back that hold the top panel. Lift it up and the valve will have two wire harnesses plugged into it with a small fill hose. I hope this has helped you. If you need to order the valve, please give my web site a chance at www.whirlpoolpartssurplus.com And please let me know if I can assist you further.
    Vic
Maytag atlantis mavt834aww stopped in mid cycle and now won't do anything.
Try unplugging it wait a minute and replug it in. This will sometimes reset the main board.
Sep 25, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My washer is not working it begins to spin stops and has the letters LE appearing.
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Goodluck..
May 27, 2008 | LG Washing Machines
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 07, 2011 | Washing Machines
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
The washer is ovrtflowing with water. It does not stop
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | GE WDSR2080D Top Load Washer
Tromm LG front loader error code
Already answered by an expert :-
Thanks.
Jun 17, 2009 | LG WM-2277HW Front Load Washer
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
Dishwashers Logo
134 people viewed this question
Top Dishwashers Experts
