Question about HP Hewlett-Packard Intel Xeon Quad-Core E5345 2.33GHz - Processor Upgrade (435564B21)
Dual E5345 Xeon -Upgrade?
I have a system with Dual E5345 Xeon CPUs on a TyanTempest i5000XT MB with 16GB RAM. The system is fast but I do fairly high end graphics work and would like to know if I can replace the CPUs with something even faster???
  • HP Master
  • 4,806 Answers
Hi there.
If you note down the make and model of the motherboard you will be able to check to see if you can upgrade to better processors and which type of processors the motherboard supports.
If you want me to source the info please post the make and model of the board.
Thanks for using FixYa!!
Posted on May 22, 2009
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
Single core 2.8ghz xeon to quad core cpu
http://en.wikipedia.org/wiki/Xeon#Prestonia
"In 2002 Intel released a 130nm version of Xeon branded CPU, codenamed "Prestonia". It supported Intel's new Hyper-Threading technology, and had 512KB L2 cache. This was based on the "Northwood" Pentium 4 core."
Meaning it is a Single-Core processor.
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Prestonia.22_.28130_nm.29
Scroll down.
400MegaHertz Front Side Bus. (400MHz FSB)
http://en.wikipedia.org/wiki/Xeon#7300-series_.22Tigerton.22
"The 7300 series, codenamed Tigerton (product code 80565) is a four socket (packaged on Socket 604) and more capable ->
QUAD-CORE processor.................."
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Tigerton.22_.2865_nm.29
1066MegaHertz Front Side Bus. (1066MHz FSB)
The motherboard uses the Intel E7505 motherboard chipset,
http://en.wikipedia.org/wiki/Intel_Xeon_chipsets#NetBurst-based_Xeon_chipsets
Note the - Processor FSB supported -
533MegaHertz
ONLY supports Single-Core processors, too.
The answer is No
Regards,
joecoolvette
Dec 17, 2012 | Computers & Internet
What is the main difference between a dual core CPU, and a Core2 Duo CPU ?
A dual core processor has two cores (essentially, two CPUs on one chip). Core2Duo is a specific dual-core processor design. Thus, all Core2Duo CPUs are dual-core CPUs, but not all Intel dual-core CPUs are Core2Duo designs.
Essentially all current Intel consumer dual-core CPUs today are Core2Duo designs. They have different names, but vary mostly in terms of their FSB speed (mostly, how quickly data can be transferred to/from RAM) and in the amount of cache memory in the CPU (cache memory is a relatively small amount of high-speed memory on the CPU chip that stores frequently-used data and instructions; it can improve performance 4-15% or so, depending on the amount).Best Regards, Luis.
Mar 02, 2012 | Computers & Internet
I am upgrading to windows 7. How much memory should go with the up grade? at present time I have1028 and512 GB installed. CPU ok for the up grade?
minimum 2GB for smooth use of the pc, but RAM is fairly cheep so I would go for 4GB. The most importet hardware to be fast is your harddrive.
Mar 26, 2011 | EliteGroup KM400-M2 Motherboard
Upgrade Intellistation Z Pro 6121 w11 to 64bit Xeon Processors
It helps if you give the right specification - the W11 is the 6221, not the non-existent 6121.
You have 2 x 2.4 Xeon in a Socket 604 package. The only CPUs these could be are the Tigerton - it certainly does support 64-bit operation, as well as VT.
You have little choice in processors - Tulsa, Tigerton and Dunnington.
The Tigerton is a little ripper! 2 x 4MB on-die cache, 1066 internal FSB, wide voltage range and low power consumption (80W).
http://ark.intel.com/Product.aspx?id=30779
You have a 4 processor 64-bit box - if it isn't poweful enough for you (and I can't see why - I run 50 concurrent VM users on less), you can only go to the 2.93 Tigerton as an upgrade. The other CPUs have more horsepower, less torque!
Don't get hung up on processor speed - for 64-bit big cache rules.
Aug 05, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Adding second CPU
Hi
Did you receive a VRM with the the PRC upgrade kit? And have you installed it?
The following items are/should be included in a microprocessor upgrade kit:
• A microprocessor (PRC)
• A heat sink
• Heat-sink retention clip(s)
• A voltage regulator module (VRM),
Your upgrade kit may also include a cooling fan.
If you are adding a secondary microprocessor, examine the VRM to ensure that it is the correct VRM for your system. Install the VRM in the appropriate secondary VRM connector, ensuring that the latches at each end of the connector engage. If you received two VRMs with the upgrade kit, replace the primary VRM already installed in the system with one of the VRMs from the upgrade kit.
Note: The system does not support mismatched VRMs.
Check PE1600sc Microprocessor Upgrade Installation Guide - http://support.dell.com/support/edocs/systems/pe1600sc/multlang/proc/9D904A05.pdf
Let me know how you get on
Mike
May 13, 2008 | Dell PowerEdge 1600SC Server
Having problems trying to get a Tyan i5000xt MB to allow the vid card to come up with a display
  1. If the MB has jumpers, you must make sure they match you CPU.
  2. Make sure you have the right memory modules and that they are installed correctly.
  3. Unplug all drive cables from the mother board (HD, CD, DVD, Etc) and then try to boot. If you see video, plug them back in one at a time.
Hope that helps...
Geno
Apr 02, 2008 | Tyan MBD SSIE DUAL XEON 5000 5100 1333FSB...
HP Hewlett-Packard Intel Xeon Quad-Core E5345 2.33GHz - Processor Upgrade (435564B21) Logo
190 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
