Where is the fuse located - Heating & Cooling
  • 8,220 Answers
On window units with a electronic control the fuse is nestled between the display panel and the board. Imposible to see or get to without removing the control.
Posted on May 22, 2009
Where is the abs fuse located on a 2003 GMC envoy please
Under hood fuse panel. Lid has the locations of fuses. There are 2 for the ABS system.
Jan 08, 2017 | GMC Cars & Trucks
Where is the 60A primary fuse located?
It can be a metal fuse located close to the battery cables or a plastic fuse located in he underhood fuse/relay center. Check owners manual for fuse locations and identifacation
Apr 12, 2015 | 2006 Suzuki Grand Vitara
Where is the fuse box on gt 5000 craftsman lawn mower?
If you think your riding lawn mower has blown a fuse, trying to locate that fuse may be the most challenging step in replacing it. While different lawn mower manufacturers have located the fuse holder in different areas of the lawn mower, the best place to start looking is near the mower's battery, according to Sears.
Some manufacturers have made it easy to find the fuse holder. Simply lift the hood. The fuse holder is molded into the metal right inside the hood, near the battery. (See photo at Ref. 3, p. 53) If the battery is located beneath the seat, you may find the fuse holder located beneath the rear fender. Other manufacturers make it more challenging, placing the fuse inside an electrical box, located behind the mower's upper air baffle. (Ref. 4, p. 28) Fuses can also be located on or close to the edge of the mower's electrical panel, above the solenoid.
If you check these locations and still cannot find the fuse holder, check your operator's manual for a diagram of the electrical system, which should display the fuse's location. If you no longer have your manual, it may be available online through the manufacturer's website. Should you be unable to find a manual, call a local lawn mower dealership or lawn mower repair shop and ask for assistance in locating the fuse in your exact model.
Jun 27, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Where are the fuse locations for 2002 explore power seats
Look under the dash left side panel for fuse panel access.
Also look in owner manual for fuse position/location assignment on fuse panel.
Apr 11, 2014 | 2002 Ford Explorer
Free fuse pannel diagram for freelander 2002
Electrical Circuit Diagrams - shows the freelander's fuses during the power distribution pages but they aren't listed by fuse box
2002 Freelander Electric Library - This most importantly shows the location of the fuse box, the fuse box diagrams with location markings, and the fuse values required for each fuse location. It also shows the connections for different sensors and a breakdown for the electrical operation of different car parts
Fuse box Diagram with relays & their location
Aug 31, 2013 | Cars & Trucks
Transmission fuse blown
It will be located with the rest of the fuses. Fuse blocks can be in more than one location so check manual for all locations. Manual should tell you which fuse is for the transmission.
Jan 15, 2013 | 1990 Nissan 300ZX
Which fuse and voltage location on fuze box of 2000 ford windstar
For power window fuse location and for all fuse number list under dash fuse box,click the link below and see the fuse diagram:----http://technoanswers.blogspot.in/2012/02/where-is-power-window-fuse-located-on.html
----------This will help.Thanks.
Feb 10, 2012 | 2000 Ford Windstar
Where is the fuse to the starter located?
Fuse 1-A (10 amp mini-fuse) located in the fuse panel under the instrument panel, and fuse # 2 (60 amp maxi-fuse) located in the right hand side under-hood fuse block.
Nov 24, 2010 | 1999 Oldsmobile Aurora
FUZE BOX DIAGRAM FOR 1990 MERCURY TOPAZ
Replacement
  1. Access the fuse panel from the left of the steering column.
  2. Locate the blown fuse and pull out. DO NOT TWIST.
  3. Take note of the ampre number written on the top of the fuse. To install:
  4. Push a new fuse of the same ampre into the receptacle, making sure the contact is being made on both sides of the fuse.
LOCATIONS Headlights and Highbeam Indicator
  • One 18 amp circuit breaker (22 amp in 1987 vehicles) incorporated in the lighting switch.
Front and Rear Marker, Side Parking, Rear and License Lamps
  • One 15 amp circuit breaker incorporated in the lighting switch.
Windshield Wiper
  • One 4 1⁄2 amp circuit breaker located in the windshield wiper switch.
Power Windows
  • Two 20 amp circuit breakers located in the starter relay and the fuse block.
Power Seats and Power Door Locks
  • One 20 amp circuit breaker located in the fuse block.
Hazard Flasher REMOVAL & INSTALLATION NOTE: The hazard warning flasher is located on the rear side of the fuse panel.
  1. Locate the hazard flasher in the fuse panel.
  2. Pull the flasher out. DO NOT TWIST. To install:
  3. Push new flasher into place making sure a good contact is made with both terminals.
  4. Test flasher to make sure they function properly.
Various Relays LOCATION Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Fig. 1: Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal
This is the best info I could find....I hope this helps ya!
Jul 23, 2009 | Mercury Topaz Cars & Trucks
ABS fuse locations
There are a total of 5 fuses for brake and abs functions 3 in central fuse box on the drivers side inside truck fuse #9 - 7.5 amp fuse #10 - 10 amp and fuse #11 - 7.5 amp then there are 2 big fuses under the hood in the main battery fuse box next to the battery fuse # 6 - 50 amp and fuse # 28 - 30 amp
Jun 01, 2009 | 2001 Ford Explorer Sport Trac
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
