Question about Hitachi 53UDX10B 53" Rear Projection Television
Power light doesn't shut off.
I have the 53udx10b.  I turn the power off but the power light stays on.  I tried turning off the power strip overnight and turning it back on the next day.  Unfortunately, the minute I turned the power strip back on the power light lit up again, even though the TV was off.  TV seems to be working ok but the problem concerns me that something may be happening that could permanently damage the tv.  I spoke with a Hitachi rep and they said it was just an LED problem, I tend not to trust the off the cuff advise given by customer service reps.  Any ideas on a fix for this problem?
  • Ladydidi Nov 05, 2007
    Power light does not shut off. Now, the T.V. will not play.
  • Anonymous Dec 11, 2007
    53UDX10B TV will not always power off and almost always comes on by itself in the middle of the night. Have plugged it into a power strip that I turn on when I want to watch the TV and off when I'm through. This is a real hassle.
Same problem just happen to my Hitachi and tech guy just left and fix it it's the relay he first gave a little tap on it and it was ok but he ordered the part and will come back to replace with the new one and voila like brand new.
Posted on Mar 13, 2008
  • 71 Answers
You're right. It's not only a led problem. Efective. the tv doesn't shutt off due to defective relay S901 in primary power supply. It's a 5 volts ordinary relay, replace it and it'll be fine.
Posted on Dec 07, 2007
Kitchenaid dishwasher 577
Does it work though? If the light is staying on after you cut power then maybe a genie is living in there :)). Other than that it could be a bulb with bad or loose connection. I do know those touch pads behave weird if there was a power cut/surge. Mine did that bit it still works. I'm just waiting to see if a light blows or if some other short happens. Anthony
Jun 15, 2013 | KitchenAid Dishwashers
Hp desktop power light comes on and then shut of and turns back on and off again.
try holding your switch in? if it stays on then you know your switch is bad ? if it doesn't ? could be a bad power supply ? hope this helps!
Jun 03, 2011 | HP Computers & Internet
53udx10b hitachi rear projection big screen. replaced convergence chips 2 months ago. Worked awesome. Started having power issues 3 weeks ago. Turn on - kicks right back off. Used to be able to turn...
Sounds like the problem started out with an intermittent solder connection possibly on the deflection PWB unless the power relay has a bad connection or is breaking down under load. If it is not the power relay, I would check the connections under the deflection board - paying close attention to the area from T701 and T752 including the Horizontal output Transistor for a short. You also have a possibility of defective filter capacitors causing the problem as well.
Jan 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
The power does not want to stay on.
TV needs major service, convergence and also the power supply expect to spend around $350.
May 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
Turns on but wont stay on
your start relay in the power supply has burned points and, loses it's connection shutting down your TV turn on the tv with the back off and, listen for the relay click to find it; then replace the relay
Jun 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Red Power Light Stays on
Hi, you have a leaky diode, it will not hurt your tv it`s just annoying, my Hitachi has done the same thing for a year and I`m just too lazy to change it out, video-tek
Feb 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Power shuts off periodically
Symptom: Intermittent shut off
Cause: Turn off program timer and video input sensor. redress cabling from front control panel away from blue crt-yoke-HV lead
May 19, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
112 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
