Question about Karcher Garden
Water spewing from the front, don't have tool to open housing
I have a Karcher Pressure Washer K3.99. When I turn it to wash, it sprays out the front and gives me only a little pressure out of the wand. I am guessing that either a hose is off or loose or I need to replace a hose. I can do that but I can't get into the housing. It requires a very unusual tool called a "Torx 15" which of source I do not have. Does anyone know either a different tool that I can use to get into the housing or where I can buy a Torx 15 other than online. Or last but not least, where I can take this pressure washer to get it fixed by a professional>
  • 92 Answers
Dear outfielde901,
Regarding the sprays out of the front, this could be to many reasons. Most common is an inlet elbow is broken inside. Even the head could be faulty. But the most important is to open the cover. Yes you need a Torx 15. A torx 15 is a very simple screw driver, that it is not flat or philips...but it has a six ended end. The screws have six ended holes. You can very easy buy a set of screw drivers and in the set you see that you have a T15. Now it is better that the T15 has a hole at the end. This is called a security screw driver. In the screw there is a little pin in the middle...so a normal T15 will not fit. If you are lucky, all screws might be normal with out the little pin. So a normal T15 will do. I bought various sets of these TORX from ebay for a very little price. If you buy a set consisting from T10 to T20 and even T30 andT50 it will be better. You can also buy these screw drivers from a normal tool shop or iron monger. My edvice first buy a T15 to open the cover.....then see what tools you need more. This because some washers they have inside Allen Screws. So then you buy a set of Allen Keys.
The other problem for you might be from where you buy spares. This I cannot help you, because I am not from your country. So remember ..a T15 is a simple screw driver. With a cheap set of Torx and a set of Allen Keys you can fix your problem yourself. Very Simple!!!!
Regards,
Fulltech.
Posted on May 22, 2009
3 Suggested Answers
SOURCE: where can I order this part spray wand extension for the Karcher
i order a new part
thank you for your help.
Posted on Jun 18, 2009
  • 104 Answers
SOURCE: karcher k2.40r pulsates
It sems you have a blockage in the tip. If you get a grain of sand in the nozzle it will act like this. Get a piece of fine wire and poke down the nozzle to free it up.
Posted on Sep 02, 2009
Testimonial: "Thanks, it's fixed. The wire didn't actually clean it out, but I used my air compressor and blew into the tip. Wonderful!!"
Why does my karcher powerwasher starts and dies after 2 minutes
dirty carb , clean carb, install a fuel cut off valve ( or start using it if you already have one) when you are done washing, turn off the fuel valve and continue spraying water until the engine stops. That will empty the carburetor bowl and the carb will stay clean until you want to use it again.
Sep 07, 2014 | Karcher 2500 PSI Pressure Washer
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
I don't get a constant stream of water from my Karcher 2500 psi pressure washer. instead is shoots in spurtss.
Make sure that while you are running your pressure washer, other machines that pull
large volumes of water like a dishwasher or washing machine are not running. check and make sure
the hose you have tied to the pressure washer is not collapsing or has any kinks in it.
check the filter where your water hose ties in to your pressure washer, make sure it
is clean and does not have any debris or hardwater buildup, clean the tip at the tip of
the wand. if it is reduced in size by hardwater buildup, will not work properly, good luck!
Jul 12, 2011 | Karcher 2500 PSI Pressure Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
No pressure coming out of hose when motor is going hard I can put my finger on the end of the spray wond and there is hardly anything Karcher 5.0hp GC160 K2400HH
First thing is remove the water supply house and check the water screen for clogs. Remove the hose washer and pull the screen out. Wash and clean the screen then re-install. Make sure your using a 5/8" hose as a supply hose and that the water faucett is turned all the way on.
If after all of the above it still has low pressure the unloader valve is most likely corroded or has debris in the seals.
Download this parts manual The unloader / thermal valve that is supposed to reset is Item(s) 9 {Valve 60 GND} and 12 {Spill Valve} of detail A on page 11. The spring, seals and housing need a good thorough cleaning to get high pressure. If the seals are damaged they will have to be replaced. Lubricate the seals with lubriplate white grease No. 105 before you reassemble the unloader valve. Grease link: http://www.lubriplate.com/webstore/default.aspx This grease is at any automotive store.
Thanks for using FixYa.
Kelly
May 10, 2010 | Karcher 2500 PSI Pressure Washer
I purchased a reconditioned Karcher 4000 and upon first use, the spray surges. It will go down to almost nothing then back up to full blast in about 5 second increments. Any advice?
Bleed the system by running water without the unit on, You have an air lock, open the drain cocks and allow water to run slowly for 2 minutes, then close everything and try it
Mar 06, 2010 | Honda Karcher G4000RH Pressure Washer
Karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Jul 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Pressure washer
Hi
don't know if this will help, but when I use mine, to start the pressure up I have to turn the nozzle to fine spray then turn it to the power spray and it works every time, shouldn't have to do this but I got it for nothing.
May 29, 2008 | Washing Machines
Garden Logo
653 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
