Question about Apple MacBook Air
Can't turn speakers back on
My Air laptop suddenly has locked the sound to 'off' and I can't turn the sound back on. Any idea how to change it back so the speakers work?
  • 221 Answers
Hi, a try would be to reset the PRAM by pressing cmd - alt - P - R simultaneously at startup untill you hear 3 startup chimes, then try to change the sound settings
Posted on May 29, 2009
Suddenly it stopped working, we change the batteries but still dead, some idea???
I am having the same problem. I replaced the battery and I was able to reprogram my code, but the lock is not turning. It makes no sound like it use to. Any ideas?
Aug 12, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
No sound is coming out of the laptop.
Opened the unit up recently and saw the problem: detached wire from the speaker. All it needed was a little soldering to attach the wire back to the speaker and presto! The sound was on again.
Oct 07, 2009 | Vtech Disney Princess Magic Wand Laptop
Laptop sound works when using earphones, but speaker suddenly doesn't work without earphones. Have we accidentally pushed a button or something?
When you plug in headphones, very often they get accepted automatically and the sound port changes in the OS accordingly as well. But when you unplug them again, it happens quite often that the OS is not switching it over on its own (even still happens in win 7). Just go into the volume mixer panel/options and change the output back to the port of your speakers.
Aug 02, 2009 | HP Compaq Presario CQ50-211NR Notebook
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sound is not working on my hp laptop
I had the same problem; my laptop's speakers suddenly stopped working but I could still use the headphones and sound was fine.
I played around a while and searched the net; and I got them to work:
Open Control Panel- Sound, Speech, Audio Devices-------->
1) Audio Tab
2) Under 'Sound Playback' hit Advanced
3) At the bottom where it has Speaker Setup change it to "Laptop Stereo Speakers" (mine was initially on "Desktop Stereo Speakers" for some odd reason)
Problem solved, Thank God (Alhamdulilah)!
Hope it works out for you :)
Dec 04, 2008 | HP Pavilion dv6000z Notebook
Vaio TXN19P no audio!
Appreciate the direct "Ask Me".
Audio problem(s) on any computer system could either be hardware (least likely) or driver issues (most likely).
That being said, you could initially try:
  • change your speaker/headset;
  • verify that the sound device is enabled in your CMOS/BIOS configuration/settings;
  • check Device Manager/Sound Controller, there should be no yellow or red markings. If so, try re-installing the drivers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Sony VAIO PCV-J200 PC Desktop
Bose media mate speakers suddenly don't work after ....
what type of computer? desktop or laptop? have you changed or added a sound-card?
Jun 24, 2008 | Bose MediaMate Computer Speakers
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
Acer 5610 sound problems
Hi, It is possible that: 1. You may have recently installed an add-on/external device such as a multimedia keyboard which changed the audio output from internal to external; 2. The laptop's internal speaker might have gone dead (highly unlikely but still a possibility) - try plugging in external speakers or a headset and check; 3. Most if not all laptops uses a female stereo babyphone jack to connect to external speakers. This jack has a built-in switch that cuts off internal speaker if an external is plug in. If you are using eternal or headset from time to time, it is possible that the switch might have locked to external and does not switch back to the internal; 4. You may have a hardware issue specifically the sound card/chipset. This of course would require an inshop repair which may be better off with an authorized service center. At worst is have the entire laptop replace if it is confirmed to be a hardware issue. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 09, 2007 | Acer Aspire 3000 Notebook
Apple MacBook Air Logo
484 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
