Compressor electrical pins are bad. Can the Compressor electrical pins be replaced?
The wiring pins to the compresor are extremely corroded. Can the input wiring connector pins to the compressor be replaced.
  • 8,220 Answers
No but you can buy a compressor lug kit at any HVAC outlet. It has 3 wires with fabricated connectors that screw onto the remaining pin. Around $30
Posted on May 22, 2009
Ac problem
jump the low or high pressure switchs this switchs are located on the a/c lines of tje compresor not run check power to the compresor if you have power maybe the compressor is gone check the a/c control pannel to and take a second opinion before expend money
Aug 04, 2012 | 2006 Kia Sedona
The compresor make a noice but not start
Faulty compressor. May be new electrics would work but most likely compressor needs replacing
May 15, 2012 | Avanti Refrigerators
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Does not cool and compressor relay keeps intermittently buzzing every 1 to 2 minutes. Condenser coils are cleaned and when you check across the overload protector pins there is no continuity.
When there's not continuity across the overload is because the compresor overheated , it could be the relay or the compressor that is burned out or stuck .I would let the compresor coold down for a few hours (unplugging the unit) and replace the relay (no more than $20) and if still having problems the compressor needs to be replaced.
Aug 23, 2009 | Amana Freezers
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
My u line icemaker was freezing water but my iemaker was not working. I just installed a used icemaker, now the compressor and fan work, but no cool. compresor conections dont show leaks, compressor gets...
If the compressor and fan are both running and no cool then you have a sealed system issue. If you just replaced the icemaker assembly and it freezes but doesnt dump then you might have the wrong icemaker or a bad thermostat.
Jul 15, 2009 | U-Line Icemaker
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
Noise from A/C Compressor
Hi,it is allways better to remove the compresor ,do to the lack of room to work on the engine compartment,by what you are telling me it sounds like your compresor is bad you may try to replace the bearing but you may found the compresor on line for the same price with less troubles. good luck.C1
Nov 27, 2008 | 2003 BMW 325
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
