Question about Kyocera FS-4000DN Laser Printer
LCD Displays "Call Service 7410:0089745"
I have a Ecosys FS-4000DN printer and there is a message on the LCD screen that says "Call Service 7410:0089745" Can anyone help me fix this problem?
  • ewestra May 22, 2009
    I am not too technical - is this an easy fix or do I need to have a tech come out to fix the drum?
    Problem Solver:
  • 6 Answers
This is a Drum unit non-installing error: drum is not installed or not installed properly. The durm PWB EEPROM does not communicate nor mally. Defective connection drum PWB(YC1) and Connect-L PWB(YC3). Maybe defective drum PWB EEPROM or defective engine PWB or itis just the drum unit itself is defective.
Posted on May 22, 2009
  • elyb May 27, 2009
    To replace the drum unit, developer unit with the toner cartridge has to removed first, then open the left side of the printer open the small panel where the waste toner bottle is located release the small tab then just slide the drum unit out. Install the drum unit ,the waste bottle and developer unit in the reverse order. Good luck. If you think you cannot do it, better call a technician.
  • leahhagedorn
    leahhagedorn Aug 27, 2012
    elyb - I had error "Call Service 7410-0061515" and I did your exact instructions above and it worked. Thank you!
Call Service 7000: 0370082 Kyocera 4000dn
Toner motor lock error ,usuall ycaused by using non manufacturer toner ,you may need to get a new developer unit
Oct 14, 2013 | Kyocera FS-4000DN Laser Printer
Hi, I have an ecosys fs 2000d, with a call service message 6000:0026965, somebody help me please
Call service message 6000 in Kyocera is a fuser error code. The fuser must have gone bad.
Regards,
Shrey
May 31, 2011 | Kyocera FS-2000D Laser Printer
How to i stop paper jams on kyocera ecosys fs-4000dn? because everytime, i remove the paper and restart the printer it again brings the paper jams. please help
The first thing you need to do is open the device and clear any debris: leftover paper pieces, toner, etc. If this does not fix the jamming, the device could use a more thorough service. Inspect all of the moving parts and make sure that they are firmly attached. If it's possible to tighten down some components, a minor tweak with a screwdriver can work wonders.
Something a little unorthodox, but that has helped me in the past is lubrication. You could try lubricating the printer with mineral oil or paper shredder oil. There are two ways of doing this. You could open the machine up, locate rollers and then brush the oil onto the rollers. Or you could simply put a very then layer of mineral oil on a piece of paper and then run the paper through the machine. The first few pages out of the machine will have oil on them, but after a half dozen pieces or so, the parts should operate more smoothly and be less likely to jam.
I hope that helps.
Mar 01, 2011 | Kyocera FS-4000DN Laser Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
Printer is showing an error message call service
Take out and reinstall drum unit. You will need to remove toner assy and waste ink bottle to do this. 7410 is the error, 98681 is the page count.
Nov 16, 2010 | Kyocera FS-4000DN Laser Printer
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer call for service 7000:0103031
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
Jan 20, 2010 | Kyocera FS-4000DN Laser Printer
My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Jul 19, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera FS-4000DN Laser Printer Logo
714 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
