Question about Zanussi ZWF1430W Front Load Washer
Wont spin renewed carbon bushes and new motor ,belt okay.can you advise where the electronic detection device is on the machine,how can it be repaired
Need to find where the electronic detection device is on zannusi washing machine f1234
  • Zanussi Master
  • 3,463 Answers
Usually located at bottom rear left of washer.
If not there, then located at top front right of washer together with timer control.
Posted on May 22, 2009
I have hoover Optima wmh139 with lights flashing from left to right it's 1 2 5 how do you read fault
here are what the numbers mean. 5 is probably throwing the others but you'll need a service tech to know for sure.
have you unplugged/cut off power to it for 10 min to see if it may possibly reset? Worth a try anyway.
Error 1 Door safety lock error
  • Check door is closed and latched correctly
  • Check wiring
  • Check door lock
  • Check drum braking device if fitted
Error 2 Not filled in preset time allowed - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
Error 3 Not drained in time allowed - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Error 4 Multiple instances of anti-flood contacts in pressure switch being made
  • Check for overfoaming evidence - can trip pressure switch
  • Check pressure switch is not defective
  • Water inlet valve locked open
Error 5 NTC fault - temperature sensor detected as either open circuit or shorted
  • Check wiring to temperature sensor
  • Check thermistor
Error 6 EEPROM failure - defective electronic controller
  • Check wiring
  • Check electronic control PCB
Error 7 Motor fault detected
  • Check motor connector block
  • Check wiring
  • Check motor carbon brushes
  • Check tacho connections
  • Check motor
Error 8 Motor tacho fault - washing machine motor tacho detected as open circuit or shorted
  • Check wiring
  • Check motor
Error 9 Short circuit motor triac on electronic module
  • Check wiring
  • Check electronic controller
Error 12 Communication error between electronic control boards and wiring
  • Check wiring and harness between control boards
  • Check electronic control modules
Error 13 Communication error between boards and wiring
Error 14 Water heating error detected
  • Check wiring to wash heater and thermostats
  • Check wash heater for continuity
  • Check NTC (temperature sensor) probe
Error 15 Defective control module - Not programmed Cuore control
  • Reprogram electronic controller
  • Replace electronic controller
Error 16 Water heating element detected as short circuit
  • Check for defective electrical insulation
  • Check water heating element
  • Check water heater wiring
Error 17 Wrong signal from motor tachometric generator
  • Check wiring
  • Check motor
Error 18 Defective control module - also can be wrong electrical input frequency
  • Check wiring to electronic controller or both if two used
  • Check electrical input frequency
  • Check mains electrical supply
Feb 26, 2018 | Hoover Washing Machines
My zannusi zwf1430 washing machine is displaing fault code e91 could you please help
E91 usually signifies a communication problem between the electronic boards. sometimes it can also be caused by a poor connection (Dirty, broken etc) or a fouled condenser fan. Check the wiring harness and connections and see if the fan chamber / vents has any dirt stuck in it. Make sure the machine is unplugged before touching anything inside the machine.
Mar 22, 2017 | Washing Machines
Could the problem be. Cos it's jumping around and loosening the screw in the centre ?
Here you have AEG, ELECTROLUX, ZANNUSI or PRIVILEG - good washing machines.
If its jumping then spinning with clothes it could be shock- absorbers problem (You could see them inside in middle). If it make realy big noise - bearings are "dead".
But in this video I cant see any problems.
Mentioned scerws are only for transportation. If you put them back your washing machine will jump like crazy :). (please, dont try it).
Apr 13, 2013 | Washing Machines
Zannusi banging
It sounds like it's unbalanced. Try redistributing the clothes and/or washing smaller loads. If that doesn't fix the problem, you may need to call out a technician.
Dec 31, 2012 | Washing Machines
My zannusi washing machine is pouring out water when on the rinse. water is coming out from front and both sides?
Hi.
The problem is probably caused by overfilling, in which case the faulty part is usually pressure switch. Check the gasket between the door and drum for leaks. Check if the inlet valve is stuck open and check that the control module is working then eventually test and replace the pressure switch, which is the part that detects water level and stops filling.
Aug 18, 2011 | GE WSXH208A Front Load Washer
The plug on my 6 year old Zannusi washing machine has just burnt out. Is it safe to replace it and try again?
No it would not be safe to fit a new plug and try again. If the plug burned out it would appear that there's a short circuit somewhere in the machine possibly caused by a leak. If you replace the plug you risk burning down the house or electrocuting yourself. I'd advise you to get a repairs man to check out the machine to see if it's repairable. It could be something as simple as needing a new door seal which would cost you around 30 euros.
Aug 31, 2010 | Washing Machines
E40 fault code zannusi washing machine.
You could look here:
RepairClinic.com (good)
espares.co.uk
AppliancePartsPros.com
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
Bendix 1500 series Washer is leaking from bottom
It is now Tricity Bendix, and comes under the ZANNUSI name.
Try looking under Zannusi in your directory
Nov 25, 2008 | Tricity Bendix AW1054 Front Load Washer
ZANNUSI TD900 Product Number 916110209 Doors can not open
Click on your brand (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Press "end of cycle" button & wait for 2 minutes before trying the door gently; do not force the door. & rate me if helped on this great site!!
Jan 11, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
138 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
