Question about Harman Kardon HKTS 5 System
Front audio channel burnout
I have HK AVR-120 receiver/amp and TS-5 surround speaker system. Second time now, resistors on amp audio board (front channels) have burned out. Amp is in open air with good venting. Never turn above 50% of max power. Have checked and have no shorts in speakers or speaker wire. Believe amp and speakers match at 8 ohm - still checking. Can't find ohm listing on any of the speakers. Will check amp when it comes back from the repair shop today. What would cause resistors on audio board in amp to fail?
I appreciate any suggestions.
Ken
  • 11,896 Answers
Resistors can fail from being turned up to hire, wires getting bumped together or against metal, speakers being wrong ohms, or just plainly overheating.
Posted on May 22, 2009
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
No surround sound
Check the wiring while it is ON, there might be a loose wiring... also check the power of the amplifier... then check the TV setting for the activation of the surround system...
Post me the results... hope this Fixya the problem...
Feb 17, 2008 | Harman Kardon AVR 630 Receiver
Humming sound (speakers)when HK AVR is powered up.
In my case the buzz was only on front speakers. There are 3 capasitors (100uF/25V) very close to the cooling ribs of 3 regulators in the power supply. In my case the C922 was bad.
Apr 02, 2009 | Harman Kardon AVR 500 Receiver
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Connecting Bose 901 series iv to Harman Kardon AVR 254
Most HK av receivers have pre amp out,power amp in with metal jumpers connecting them for the main or front channels. that would be the best place to hook up the EQ on a AV receiver. If your receiver doesn't have pre out, power in jacks , you can use tape monitor .record out playback in. The tape monitor option is best for stereo use , as the active EQ will charge all speakers in tape mode, possibly damaging other speakers.I run my 901 s with a seperate pre-amp,power-amp hooked up to my Denon AV receiver that way i can run in surround w/standard speakers
Jan 06, 2009 | Bose 901 VI Main / Stereo Speaker
Denon AVR-2307 Protection Circuit Activated permenantly
The speakers are 4 ohm speakers, a guy on another chat site sent me a link to the impedance curves http://www.audioholics.com/reviews/s...t-v2-fs/page-4
He agreed to that there was a mismatch as the unit has plenty of fresh air around it, plus all the speaker cables have been tested and installed correctly.
So, off to the store where I got it from tomorrow.
Jan 02, 2009 | Denon AVR-2307 Receiver
HK AVR 120 (left speaker not working)
Hi, your analysis are right, your speakers has no problem, the problem is in your receiver.
there are several factors that affects it, try some troubleshooting: and answer this questions:
1. During this event, what is the source of your INPUT audio signal?
Have you tried to replaced your RCA cables that connected to the source of your receiver?
If YES, then problem really exist in the internal system of your receiver. may be you have overdrive your receiver unintentionally, which cause the Power Amplifier to malfunction,
On this event, I would suggest that you bring your receiver to it's Service Center for repair,
This problem needs technical troubleshooting of a qualified technician.
Dec 25, 2008 | Harman Kardon AVR 120 Receiver
Creating a surround sound system
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 16, 2008 | Harman Kardon AVR 520 Receiver
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Pierre
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
No sound from "Front Right" channel
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: MOST HK equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take this beast in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the left front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. HK is among the best equipment money can buy, and their equipment is pretty much "bullet proof!" Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 02, 2007 | Harman Kardon AVR 325 Receiver
Harman Kardon HKTS 5 System Logo
135 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
