Question about Harley Davidson 426290 AM/FM Radio
Cd will not eject from unit
On 2005 flhtc the radio works fine , I put in a cd and it plays well . The problem is that the cd wont eject. I hear a strange noise coming from the inside of the unit , at this time I cant listen to the radio, I'm stuck with the cd inside the unit.
    Problem Solver:
  • 14 Answers
I can help email HRmotors@aol.com for repair info
Posted on Jul 03, 2009
CD Wont Eject & Mode Wont Go to "CD MODE"
I suspect that the rubber belt that drives the eject portion of the unit has broken. I suggest you remove the unit and have an teckie look at it. belts are available for most makes from tandy or other electronic parts shops.
May 09, 2013 | 2005 Honda Element
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Jun 03, 2012 | 2007 Toyota Camry
My 2005 Chevy Malibu's 6 CD changer will not play CD's, and will not eject them either. When I press the eject button it appears to try and eject as I hear movement but after a short bit of clicks I get a...
Extreme heat can cause warping and the cd will not evenly eject or exit the slot. the player may have to be removed and the cd physically extracted from the player. Delco players have a lot of plastic cogs, flywheels and gears in them that get old and crack or split. Hence, the player can no longer spit out the CD.
Jul 26, 2017 | 2005 Chevrolet Malibu
It wont play cd just keeps saying e1 eject cd radio plays fine
look for areset botton if it dosent have one by a cd cleaner if after that its the same replace the radio
Jun 11, 2010 | Panasonic CQ-DFX403U CD Player
Trouble Ejecting CD. CD not playing
One thing have you tried to pull the CD out?
Dec 09, 2009 | 2001 Dodge Caravan
I cannot get the CD player to eject the CD. the radio is a standard AM/FM radio with a CD player in a 2005 Ford explorer XLT. after pushing the eject button the radio screen blinks ''EJ err''. The cd...
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
Sep 30, 2009 | 2005 Ford Explorer
CD "error" 2005 Corolla SE
INTERNAL FAILURE,, NEEDS RADIO REPAIR,, CK COST MAYBE CHEAPER TO GO AFTERMARKET OR EBAY
Jul 31, 2009 | 2005 Toyota Corolla
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
Toyota dashboard CD player won't eject
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
Oct 04, 2007 | 2003 Toyota Celica
Harley Davidson 426290 AM/FM Radio Logo
288 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
