Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer taking too long to dry a load of clothes.
The dryer is giving off some heat but it is taking 2 - 3 hours to dry a load.
  • 11,896 Answers
First thing I would do is clean from screen filter all the way out. I would clean and vacuum all the dust in the vent.
If problem still persists, I would have the heating element replaced
Posted on May 22, 2009
Tip
How to receive the best dryer repair help on FixYa
There are a couple of things that you should include in your dryer repair question so you receive the quickest and most accurate answers.
1. Model Number
The model number can be located on the model/serial number tag that is located on the dryer.
Make sure you get the full model number from this tag and not the model number from the owners manual.
The model number from the owners manual only includes the first few digits of the full model number because they include that owners manual with many similar models of dryers.
With the full model number I'm able to look up factory service manuals, tech sheets, wiring diagrams, factory service pointers and so much more.
2. Detailed description of the problem
At the very least give a brief description of the problem you are having with your dryer.
Descriptions like 'My dryer don't work' is not very helpful.
Describe what is not working. For example is the not heating? Maybe the dryer is heating, but takes a long time to dry?
The more details you can give the better. Instead of saying 'The dryer is heating, but takes a long time to dry' you could go into more detail and say something like...
"I put a load of cloths in my dryer and set it on the auto dry cycle. When I went to take them out two hours later the dryer was still running. The cloths were still a bit damp too. Most of the time I can dry a load of cloths this size in one hour. Why is my dryer taking so long to dry?"
Following these couple tips can help you get a faster and more accurate reply to your dryer repair question.
on Aug 03, 2011 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My dryer takes almost 2 hours to dry a normal load of clothes.
You have a clogged vent , or kinked vent hose , or the hose to the outside ( possibly in the wall ) , is clogged with lint . A dryer , either heats , or doesn't heat . The venting , is what causes the excess timing , for the clothes to dry .
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Takes 5 hours + to dry a load of clothes.
It should never take 5 hours to dry a load of clothes. If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is caused by poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please let me know. I hope this helps you.
Dec 21, 2009 | Kenmore 62602 Electric Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Dryer takes hours to dry one load of clothes
I WOULD SAY YOUR DRYER NEEDS CLEANING OUT OR YOUR WALL VENT IS CLOGGED AND NEEDS CLEANING OUT-MIKE
Mar 04, 2009 | GE Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Long drying time
Did you find what it was?
Mar 12, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
211 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
