Delay 8 hours button doesn't reset
Frigidaire washing machine, front loader. the delay 8 hours button is on and i can't reset it. It stays on even after i press start and pause/cancel for 5 seconds. What can i do? thanks!
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
Have you had a storm or power surge lately. May need a new electronics panel installed. That is what happened to mine. Once it is fixed, you should get a surge suppressor that is made for major appliances
Posted on Apr 27, 2008
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
IFIXALL
  • 868 Answers
SOURCE: machine stuck on pause/err
un plug the washer for 5 minutes and re try
Posted on Jun 03, 2008
SOURCE: Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Posted on Aug 26, 2009
  • 767 Answers
SOURCE: how do i cancel the delay program on the haier
Hold down the delay start and cancel buttons simultaneously and the machine should cancel the delay start program.
Posted on Jan 26, 2010
My 8 hr delay button is stuck on help!
Good Morning Friend,
I understand that the 8 hour delay button is stuck on your Frigidaire washer, model# GLTF530DS. With the model number that you have provided, I do not show that there is an 8 hour delay button. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I ask that you please leave me the model number of your appliance. Typically this can be found either on the back of the door or around the edges where the door meets your washer. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire GLTF530DS Front Load Washer
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
The 8-hour delay will not reset
You can try this is you want. I can't promice you yhat it will work but it might be worth a try. Make sure the washer is on Press and hold the "SPIN SPEED" and the "SOIL LEVEL" buttons together, continue holding the buttons until a signal sounds then release them. This should reset your washer to the default factory settings.Hope it works for you. And you might also try unplugging it and see if it will reset it. GOOD LUCK !!
Feb 17, 2010 | Frigidaire FTF2140FS Front Load Washer /...
My frigidaire will not go through any cycles>
It may have defaulted to 8 hour delay, ours did after a storm and the power went off, see if the 8 hour delay button is lit, if so press to return to instant wash.... hope this helps
Dec 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FTF2140ES0 Front Loader
Do you leave the door open between washes? If not, the innards will stay damp, and you'll get mold.
Pretty much all front-loaders have this problem...
Nov 20, 2007 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
