FixYa.com
Tags:
Toshiba DKT-2020 Corded Phone
Toshiba dkt 2020 (by 2 users)
posted by mikeyboy1951 on Oct 19, 2007
I bought a toshiba dkt 2020 phone on ebay. It has old numbers programmed in it and only works on speaker phone. I swapped out the phone with another one and now it's doing the same thing. I was trying to setup headset at the time.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 14, 2007
CAn you tell me were I can get the off-hook repair kit?
Thanks
Ron@htdf-inc.com
Solution #1
posted on Jun 05, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I'm having the same problem-- I have several phones that do not have a working hook switch. Is there a way to repair/fix this myself? Or is it something I'm just going to have to pay to have someone fix?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 12, 2007
Not Rated (0)
Priority1
Rank:Wiz Wiz
Rating: 84%, 257 votes
These phones do not store information of any kind. All the programming and memory is in the phone system itself.
The phone only works in speakerphone mode because the hook switch is broken. It is a VERY common problem that will happen to all of these Toshiba DKT2000 series phones at some point. The hook switch starts out just disconnecting calls and eventually will not let you use the handset at all. Unfortunately the problem can actually get worse even when the phone is not in use. That is why buying this series used is dangerous. Make sure the seller has replaced the hook switch and try to get a warranty.
Comment by Priority1, posted on Nov 12, 2007
Oh yes,
Just a warranty when buying these used is no good. If the hook switch has not been replaced it WILL need to be repaired. If you are lucky it will break before the warranty ends and the seller will honor the warranty. Regardless you will have the aggravation and expense to ship it back. Make sure the hook switch is new... every time... before you buy it.
Can you Help with these Phones problems?
Toshiba DKT-2020 Corded Phone (dkt2020sd)
Incoming calls blink red
My incoming calls blink red... Answer This...
Release Button?
I would like to know how to... Answer This...
change ring tone
Hi- just started as new office... Answer This...
phone system(toshiba) downb
our toshba phones are down... Answer This...
page
my page button is busy on all... Answer This...
Repair Service
Find Phone Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
