Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Dead Microwave The power went out during a storm and the microwave is dead. I replaced the 20 amp 250v fuse behind the control panel. When i plug it in there is a popping sound a spark from the plug and nothing.
    Scholar:
  • 70 Answers
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
Posted on May 22, 2009
  • 40 Answers
Push the GFI receptacle "reset" button if that circuit has one. It usually protects more than one receptacle and may not be the one your microwave is plugged into.
Posted on Jun 15, 2014
We have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
The original problem, was probably caused by a bad door switch along with the fuse, now there is a good chance the control panel is damaged, you will need a professional to assess if the item is worth fixing.
Apr 21, 2012 | Magic Chef Microwave Ovens
Frigidaire microwave continues to blow 20 amp located behind the control panel when attempting to heat items
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
We would need the model number to help you further, but would be happy to give you more DIY tips.
Chances are we can point you to the service manual online.
Jul 07, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
GE JES1344SK01 countertop microwave, no power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall, in which case you can download GE owner's manuals and installation instructions here.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams by entering your full model number here. Once you have the part numbers, though, I would suggest ordering parts here at a much lower cost.
Dec 16, 2008 | GE JES1344SK Microwave Oven
Microwave went dead
You should also check the high voltage rectifier diode to be sure it's not shorted too: http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find an authorized Panasonic servicer here. You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Nov 02, 2008 | Panasonic Microwave Ovens
Replacing the fuse of a MCO160UW
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Magic Chef CMV1000B Microwave Oven
My Jenn-Air microwave oven went blank last Friday during the storm,model no. M140
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Jenn-Air Microwave Ovens
R-4H84 Sharp Carousel II microwave oven stoped working
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
Jun 19, 2008 | Sharp R-1490 Microwave Oven
GE microwave oven - just stopped stopped working
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Jun 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
303 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
