Question about HP Computers & Internet
Melting plastic smell/ computer slow and shuts down after about 15mins
The tower starts to smell once it's been on a little while. Now it shuts down after about 15mins. Smells like burning/melting plastic/rubber. What to do? HP Slimline tower. Part replaced last October due to same thing. Now out of warranty.
  • NitrusInc
    NitrusInc May 11, 2010
    Which part? Power supply? Consider upgrading to a higher output supply if this issue is persisting.
  • Dick
    Dick May 11, 2010
    Replace the part again.
  • HP Master
  • 4,806 Answers
Hi there.
The reason you can smell burning plastic and why its shutting down after a short time is because its overheating. This can be caused by a build up of dust on the CPU fan, overtime with dust build up computers struggle to keep themselves cool and tend to shut down unexpectedly, chances are this is the problem with your machine, my advice would be to remove the power cord, open the side panel of the computer and clean all the dust away from inside the tower, do this with a soft, clean paintbrush making sure you remove the dust carefully and gently, also make sure the CPU fan and the heat sync behind it is completely free of dust or any other foreign objects.
Once you are happy that its clear of dust, close or return the side panel, plug in the power cord and turn the PC on, you may find that the PC will stay on for longer with the smell dramatically reduced.
Please post back with the results and thanks for using FixYa!!
Posted on May 22, 2009
Burning rubber smell when slowing down in an 89 Ford Bronco XLT?
Check under the car and look for a plastic bag that may have melted on the exhaust.
Feb 20, 2014 | Ford Bronco Cars & Trucks
Tip
Clean your CPU Tower every once in a while.
If you want your computer smooth and to not make alot of noises, clean the CPU Tower. Dust can collect in the fans and slow the fans down.
on Feb 09, 2010 | Computers & Internet
My maytag dryer is making a very loud noise near the area where the belts are, the belts seem to be working and the drum is turing, however after a while there is a burning smell.
Is the burning smell like plastic? If so read on. The belt runs on a spring steel plat tensioner with platic wheels of course. Plastic is on everything these days, huh? Well anyways the wheels the belt rides against has bushings inside them to make them last a long time which they do. It seems the plastic wheel will melt down in some spots and when rotating it makes the drum of the clothes dryer make a rumbling sound. I know you did not mention that problem although if the wheels keep on melting down the smell will subside but the noise will get loader as time goes on.
Jan 25, 2010 | Dryers
PS3 freezes up, then shuts self off
yOUR pS3 IS BROKEN OR SOME THING IN IT HAS MELTED THE PS3 CAN OVER HEAT iF UNDER WARRANTY YOU SHOULD RETURN IT
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
Melted Crockpot!!!!!!
Was anything in the crockpot at the time it melted?
Jan 19, 2008 | Ultrex Digital Controls 6.5-Quart
KV7-V power supply
follow the power cable from the PSU to the motherboard and see if the 21 connection has melted to the motherboard. You are better getting a 500W silent type, but it depends on the peripherals you have installed, try www.ebuyer.com for various makes.
Oct 09, 2007 | Abit KV7-V Motherboard
Computer Shuts down and won't start up
yes it could be, although the hdd wouldnt work either, unplug the 21 pin connector from the power supply unit that is connected to the motherboard power connector and see if the plastic plug has melted into the socket, if you cant pull it out theres a good chance it has.
Sep 04, 2007 | MSI KT4V (MS-6712) Motherboard
Notebook smells like burning plastic.
If the new Targus charger is really rated correctly for your laptop, your battery isn?t charging and you smell the burning plastic coming from the laptop when you plug it in that is a fairly dangerous situation and you shouldn?t plug it back in anymore. The power from the charger runs through a PCB board which distributes power to other components in your laptop. I suspect one of the components (probably a capacitor) had a catastrophic failure and is the cause of the smell and the lack of battery charging. Once again assuming that the Targus is the correct one for your laptop current you probably have a laptop damaged beyond home or economical repair.
Dec 02, 2006 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
834 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
