Question about Nu Mark Numark Cdn36 Dual CD Player CD Player
Cdn 88 not reading cd
I have a next to new cdn 88, all of a sudden the mixer stop reading the cd's, I've took it to a couple of shops but no one is willing to work on it, has anyone had this problem? is there a fix or something I'm not doing? all the lights turn on it try's to read the cd then says NO DISC??????
  • 6,784 Answers
Hi, the main board will issue this (no disc) error code when the lens assembly is malfunctioning. this assembly incorporates the lens head and body and tracking rail. this rail has a motor and gear assembly that has to work in unison in order to track and read properly. the (no disc) error is signaling ga serious malfunction within this assembly. it is not tracking. this will cause errors and the lens will not be able to scan for data to transfer to the main board for track display and info.
numark does all the repairs in house so, you will have to send this unit to numark for the lens assembly replacement. it has failed.
Posted on May 22, 2009
I have a numark cdn 90 one side stop reading the disc but what is strange it not saying no disc and the door opening and closing i did change the whole cd mechanism brand new original from numark same problem could someone help
Posted on Sep 05, 2011
  • Service4you Feb 06, 2012
    I have changed the mechanism, bit I still have the same problem! I have heard that this has to do With and error on the logic board , in My case the left, bit i do not know if this are sold as spare once? Does anyone know?
  • Joseph Bobb
    Joseph Bobb Feb 06, 2012
    my problem with the cd not reading is now fixed it was not the lens was the pcb board had was to change work great now
    President:
  • 1,348 Answers
As an electronics technician for 15 years, and kenwood,rotel,hafler,arcam,and more warranty service,here is my advice.....1). when a disc is loaded ,the clamper assembly loads the disc on to a motor that spins at 600rpm in the center,and 250rpm on the outside ,as it is a larger circle.and a laser and a photo pick up reads small pits in the oxide coating of the cd.
if the motor does not spin fast enough,the "eye pattern" created by the laser is not readable and the cpu will say no disc.
2)if the laser,mounted on an assembly which is driven by either a belt,gear,or electromagnetic slide mechanism does not dock in the center,it will not read the lead-in data on the disc and say no disc.
3)if the laser diode pick up has damaged suspension components ,or the laser is burnt out,it will say no disc.
there is a eye pattern test point viewable with an oscilloscope,if the eye is absent,the laser is burnt out more than likely.. but there are other causes,such as 4) poor grounding that philips had an issue with,......try putting the unit on top of a metal surface,and away from another components like putting it on top of a digital reciever. the digital tuner signals can actually get into the cd and cause a malfunction if the cd has a plastic bottom...there are other issues,and you may want to ship it back to the manufacturer to look at. hopefully i was of some help.
Posted on Jul 22, 2009
Kitchenaid mixer kv25g0 stop working after five minutes
These mixers have a circuit board and sensor which govern its operation. The Service Manual may help:
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
The 5 and 6 quart machines are the same except for bowl capacity.
Sep 05, 2014 | KitchenAid KV25G0X Stand Mixer
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
I have a numark cdn 88 just change the transport assemble but the cd wont spin and give me no disc on the display
Chances are that you didn't reassemble the unit correctly or damaged a ribbon cable or limit sensor. Re check your work. Pay attention to small circuit board attached to the spin motor RF310T-11400. De-solder the small circuit board on the 2 motors..and apply 12v to the spin motor. See if it spins with no dead spots on start up. when asseembled, motor will only operate and spin up to the proper RPM only if loading is successful and tray is fully closed ..etc. Hope this Helps. I have a CDN-88 in my shop for skipping issues on both CD players. so I saw your problem here while doing research. Good Luck,
Thanks, Dillon, Trace Electronics, Barrie, ON, Canada.
Jan 20, 2010 | Nu Mark Audio Players & Recorders
Problem with numark cdn 88 disk loads but does not read
my best suggestion, if it won,t read any discs then it need repairing. go through your newmark retailer .they can normally get it fixed by numark. newmark players do go this way unfortunately. if it happens again ,don't buy cheaper models in future. i have had numreous problems with numark axis 9 cd players and in the end i replaced them with a different make.
Nov 10, 2008 | Audio Players & Recorders
I have got a Numark cdn-88 cd players for my work as a DJ but draws wont open on both sides and it is clicking when I turn them on
The loading mechanism is out of alignment or the start/stop sensors are defective. Either case should be a simple repair for any audio repair shop.
Dan
Oct 01, 2008 | Audio Players & Recorders
CDN-88
If this is new, don't waste any time on it. Return it for exchange. It is rare, but sometimes the optics fail. This should be under warranty.
Dan
Sep 30, 2008 | Numark CDN95 2-Disc CD Player
Nu Mark Numark Cdn36 Dual CD Player CD Player Logo
824 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
