Question about EliteGroup ECS MB L7VMM+ W/ CPU-ATHLON 1800+; MB-K7 VIAKM266 SocketA FSB266MHz 2DDR AGP4X (NEWITEM22594099) Motherboard
Not power on.
My computer with ECS L7VMM3 vers3.0 socket 462 motherboard is no longer turn on.Is there any solution in these problem?
  • 1 more comment
  • CONSTANTIN SPYROU May 11, 2010
    Do you know how often , there can be no connection and it is not the CPU? about 99% of the time. The first thing to check is to get fair quality volt-ohm-ammeter and check the voltages. There is almost always a +3.3V (brown), +5V (red), -5V (white), +12V (yellow), -12V (blue), +5V-SB (purple), Common (black), PS-ON (green), PW-CK (orange). This will give us an idea, if the Power Supply is functioning. If so, then you neeed to check all the plugs that come out of the Power Supply and make sure that they all are well push into their connectors. You should turn the computer off, any time that you will be checking, not so much the voltages, but the plugs. If there is a spark, it could have disasterous reprications with all the high impedance parts, including the CPU. Please, gather all this information and communicate it to me. My e-mail is and my name is Constantin. Please note that I have not established my position here with the management, so, all of what I said may be modified by them.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    There are plenty of reasons as to why a computer will not switch on, please can you give us as much details as you can, for example does the computer receive power or are there any LED indicator light that light up when the power button is pressed?
    Regards
  • Dick
    Dick May 11, 2010
    There are a lot of reasons it might not turn on. You need to give some information about the problem. Exactly what happens when you try to turn it on and what you have tried to fix it.
    Is there power at the electrical outlet?
    Is the computer plugged into the electrical outlet?
    Is the power cord plugged into the computer?
    Is the computer power supply turned on?
    Are you pressing the power button or the reset button?
  • 600 Answers
I will assume you confirmed power at the outlet. so is there power coming out of the power supply? if yes then the problem is the MOBO
Posted on May 23, 2009
Compatible processor in K7VMM ecs motherboard
According to the ecs website :
http://www.ecs.com.tw
the K7VMM version 1.2A has a cpu socket 462 for AMD Athlon XP/ Athlon / Duron processor
Go to : http://www.ecs.com.tw/ECSWebSite/Index.aspx?MenuID=0&LanID=0
and use the ECS search box with your model # K7VMM
then choose your version #, click it
then click on the CPU tab (under the pic of the motherboard). It shows a complete list of compatible cpu's for this motherboard. Did this answer your question?
Dec 25, 2012 | EliteGroup K7VMM Motherboard
I have a K7sem Rev:1.0 Socket 462 motherboard with 448 mb ram, and would like to increase if possible .
Your motherboard will support a maximum of 1GB of memory. It uses PC133 / PC100 memory in two slots (512 Mb in each one)
Dec 19, 2012 | ECS Elitegroup K7sem Rev:1.0 Socket 462...
L7VMM3 motherboard is it upgradable?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=418&DetailName=Feature&MenuID=24&LanID=8#fragment-FAQ
This mainboard uses socket A 462 cpu type.
Look for a amd athlon 3000.
The duron is too slow.
As you know this is only single core.
This cpu can not be bought new anymore.
But a used can be found.
You can upgrade the ram to 2 gb max.
It uses ddr ram.
Good luck
Dec 03, 2012 | Computers & Internet
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
How can i use 1x2 pc2100r ecc mem modules on an l7vmm3 motherboard
Two 184-pin DDR DIMMs sockets for 2.5V DDR SDRAM (DDR266/DDR200)
Maximum: 1GB (Unbuffered Memory)/ 2GB (Buffered Memory)
Yes, regestered EEC modules are "buffered", so you should be ok at 2 gigs.
Nov 23, 2010 | EliteGroup ECS MB L7VMM+ W/ CPU-ATHLON...
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
K7VTA3 v6.0 Motherboard - What Faster processor can I install
AMD Athlon XP 3000+(.13u) (512K,333,Socket 462) according to website
Dec 02, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
I have a L7vmm3 motherboard - everything is
If you have onboard video disabled in BIOS, then the driver can't find the video chip.
Enable onboard video in Bios and you should then be able to install driver.
Hank
Jun 09, 2009 | EliteGroup (L7VMM) Motherboard
Computers & Internet Logo
69 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
