Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
LCD Monitor takes time to display HANNS.G Model
Monitor takes nearly 1/2 hour to display properly when turned on...
  • 1 more comment
  • suresh chandra May 26, 2009
    Which capacitor there are loads of them...
    Which capacitor plz...
    Hi. can u suggest how to find out if the capacitor is actually working or failed, i tried with multimeter it shows weird values, is there ne other equipment to test if the capacitor is actua;ly working or not...thx for ur time..don't worry abt ur english it rock's :)
  • 94 Answers
There is leak capacitors problem inside of your monitor they need to be replace so that your monitor work normaly
Posted on May 25, 2009
  • Joel Cruz
    Joel Cruz May 26, 2009
    looks like this defective capacitors look at the top of capacitor that is not good capacitor it suppose to be flat on the top of capacitor
  • Joel Cruz
    this one is good capacitors see the defference sorry to my English
Screen keeps displaying "adjusting...."
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
Hannspree HF289H Black screen SIngle orange light once and completely unresponsive
There is two chance for theis problem. 1) there is missing voltage to the back light inverter boadr or 2) the back light inverer is faulty. Check the power supply volatge to the back light inverter board. Normally its 24v for all lcd back light inverters. If the power supply is ok then you have to replace the back light inverter board.
You can check is there is any picture on the lcd screen by the help of a tourch . light the tourch near to the lcd screen and wach the screen from different angel while the PC is in ON position.. in some angle you can see the shadow of picture if every thing else working fine except back light.
If so there is powersupply missing or back light iverter is faulty. You have to replace the back light inverter board with a new on because there is no repair possible with the board. Also the spares will very difficut to get.
Ajin
Apr 01, 2012 | Hannspree HF289HJB 27.5 in. LCD TV
For the past few weeks my Hanns G 19 inch LCD monitor keeps having troubles displaying a screen. It constantly makes a loud sound that it repeats and it takes several hours before the green light appears...
From the description you give, this sounds like a failure in the circuit board, normally the capacitors go and the thing refuses to power up, however, the fact it defaulted to a low resolution indicates that the actual board is in some way failing, possibly a damaged circuit, or component.
I would think it could be repaired and it may be a simple job for someone who can identify the failing component, however, I think that the cost of getting it repaired would outweigh the cost of replacement
Jun 22, 2011 | Hanns.G Corporation Computers & Internet
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNS·G JC199DP LCD Monitor 19...
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Monitor takes up to and over an hour to boot up !
Sooner or later it will not work at all. Time to go shopping - not worth fixing. Go ebay for great prices on used/new units. eBayeBay
Sep 15, 2017 | Hanns.G Corporation JW-199DPB 19" LCD...
Hanns g 19 inch monitor
No direct experience of this specific monitor, but LCD monitors in general seem to be susceptible to power supply failure due to the relatively cheap capacitors they use and the high working temperatures.
Turn it off, leave it for an hour or two, then take off the cover and look for bulged or leaking cap's on the power supply board. If the tops are not flat, they're probably duff, and need replacing with equivalent spec ones. Probably 105'C high temp - I got 105'C 470uF 35V ones for my monitor from Ebay at about a fiver for a pack of ten.
Aug 27, 2008 | Hanns.G Corporation HX191DP LCD Monitor
Hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
293 people viewed this question
Top Hannspree Computers & Internet Experts
richie46
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
