Question about Philips DVDR3440H DVD Recorder/HDD Recorder
Drive is blocked sometimes
I have the followed problem with my two year´s old DVD-recorder DVDR3440H (Philips: Sometimes, in the last time more than before, I cannot open the drive of the recorder. At the display you can read: "BLOCKED". After some tries it runs, next time egain not. What can I do?
I have the same problem with my DVDR3440H.
I have disassambled the recorder, and I have understand that the problem is in the plastic cover of the reader box that sometimes (or always) block the drive.
at the last, I have open a hole in the case, in the top near the left side, and when the problem appear, I pull gently the plastic, and the drive open.
Posted on Nov 24, 2009
  • 50 Answers
Dvd player is jammed and wont open can you help
try taking the outside cover off then you might be able to manually open it .
Jan 28, 2015 | Philips DVDR3440H DVD Recorder/HDD...
Status on recorder says load and I cant move it off there
I would take the other route: The remote can be tested without the unit--all shops(ours does) have a tester--point the remote and press any or all buttons and the tester reacts if the remote is sending a signal.
Some digital cameras will react in the same way on their display screens in a dark room with a flash.
check the remote first.
Jun 14, 2012 | Philips DVDR3440H DVD Recorder/HDD...
My draw will not open
Hi, If you hire sound of motor (when you push the switch) who open the door then is rubber band on wheel inside DVD, or cd is stuck inside. In that case you can hook door with something and pool up easy! If no light on displey, or don`t hear motor (when you push the switch) then is electronic circuit in DVD, then you must go in service.
Good luck.
Feb 27, 2011 | Philips DVDR3440H DVD Recorder/HDD...
Convert DVDR3440H to multi region
Hey! You may need a DVD Copy software which can make makeup of DVDs. You can have a free try of Wondershare DVD Copy.
Hope that helps.
Sep 20, 2009 | Philips DVDR3440H DVD Recorder/HDD...
Which blank dvds work best with phillips dvd recorder 3440h?
dvd-r are more universal if you plan on giving the copy to somebody. they are more lickley to play on older dvd players. they are not rewriable though one time record. also do not purchase spindles the bottom of the stack usually gives you problems when finalizing
Jun 03, 2009 | Philips DVDR3440H DVD Recorder/HDD...
Philips DVDR3440H Our DVD recorder is playing up, insofar as the disc tray won't open. Each time I press the OPEN/CLOSE button on the front of the machine, the LED says OPEN and then BLOCKED. This then...
Disc loading mechanism fault. Might be of a broken gear wheel or a drive belt. In rare cases, the mechanism replacement should be done. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 08, 2017 | Philips Televison & Video
I have a phillips DVD recorder DVDR3350
my dvd recorder has the same problem press the open/close button if this doesnt work when you press open again try hitting it very lightly on top as that is what i have to do to mine to get it to open sometimes
Dec 14, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Philips DVDR3440H DVD Recorder/HDD Recorder Logo
982 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
