Question about Vizio Gallevia GV42LF 42 in. LCD Television
Replace a fuse in Vizio TV VO32LHDTV
I plugged it to 220V instead of 110V and now it won't turn on. I think the fuse is blowen. How can I replace the fuse?
    Problem Solver:
  • 9 Answers
The fuse is a round type soldered into the power supply curcuit board. This board is not the board that the power coard plugs into, but is located on top to the right with a screen metal covering. The power supply leads run to the top of the board . Two wires on a connector blue and brown. The round black fuse thing is right below the brown wire. Not sure were to get a replacement fuse, will have to unsolder it from the board.
Posted on Feb 23, 2010
  • Brian Hogue Feb 25, 2010
    I am replacing mine its a Bel fuse Inc 4amp manufacture #
    MRT 4AMMO. Waiting for a quote.
  • Brian Hogue Feb 26, 2010
    Couldn't find any place to buy the exact replacement fuse (unless I bought a min order of 100) so I stopped at the local electronics store, bought a 4amp slow blow vxp fuse and fuse holder with solder connections. Soldered on a small lenght of wire to the holder and circuit board. Working fine after the replacement and next time all I have to do to replace the fuse is unscrew the holder.
By mistake I plugged in my Harman Kardon elegant 2.1 system into 220v instead of 110v. No there is no power. Please advise.
There is an over-voltage protection fuse, but, it is inside the transformer. It can be replaced by experienced service technician. Contact any one such.
Oct 03, 2013 | Audio Players & Recorders
110V fan has been plugged in 220V power socket
You may be lucky enough that the capacitor exploded from the 220 volt charge. You will have to enquire at an appliance repair shop for exact advice. Basically I would junk it and get the correct unit for the voltage and cycles in you area.
May 17, 2013 | Dyson AM02 Tower Fan
Dont turn on
first check the supply of the TV, check if there is 110V or 220V on your voltmeter if there is a supply, check for busted fuse that is open reading on the multimeter on a diode test. replace the fuse with the right specifications to avoid further damage, then if it is not turning on after the fuse is replace check the power supply of the TV is is located on where the main plug of the TV is mounted. maybe there is a shorted transistor of diode.
Jul 22, 2011 | Televison & Video
My Sony Bravia LCD TV Got 220v Wile It Should Get 110v,And Went Off
hi...if you have plug the TV in 22oV instead of 11V..it automatically blown the fuse..the power supply has this Varistor it will shorted and blown the fuse if detected high voltage....I suggest you replace the fuse and check for any other defective parts in the power supply section....check for bloated capacitors.. shorted power switching transistor... if none TEST RUN..let see if your TV will switch ON...please rate and vote...
Feb 17, 2011 | Televison & Video
I want to put machine in my house but need 110 motor instead of 220. nothing wrong with motor or control box
I'm assuming that you brought a vacuum cleaner from a country that uses 220V to a country that uses 110V.
You either have to change the motor to a 110V motor, or find a way of plugging the cleaner into a 220V supply.
You could contact the manufacturer and ask them if they have a 110V replacement motor for your model. (Safety warning... it will take double the electrical current, which will cause four times the heating in the cable; this could be dangerous.)
A better solution would be to have an electrician fit a 220V outlet in your house. The pin arrangement will be different to prevent 110V deviced being plugged in to it. You'll have to cut the existing plug and replace it with the correct one for that voltage for your country. (I have used a British 'Dyson' in this way, plugged in to a tumble-dryer outlet; I use a GFI for extra safety.)
Jan 19, 2011 | Vacuums
Over-voltage connection - 220v - instead of 110v
That thing is fried.If you can do your own electronic repair,there are a few components where the plug comes in that would be cheap to replace.Without a solder gun and voltage meter though I would replace.
Jul 20, 2010 | Timex Auto-set Clock Radio
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Vizio Gallevia GV42LF 42 in. LCD Television Logo
5,759 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
