Question about Canon imageRUNNER 2000 Copier
SYSTEM ERROR E805
System error e8o5 for canon ir2016.how to fix it?
  • Anonymous Mar 29, 2014
    ERROR
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
You have a fan that is not working
Posted on Jun 08, 2009
Canon 405 error code e805
http://www.copytechnet.com/forums/canon/9744-canon-gp-405-error-e805.html
Quoting:
  1. Canon GP 405 error E805
    E805 (The fan rotation is faulty.)
    If no detail code is indicated,
    suspect the feeder fan (FM1) or the
    reversing guide cooling fan (FM9).
    Is the connection of these fans
    normal? Is the drive signal of the fan
    identified in the previous step about
    22 VDC while the fan is rotating orabout 12 VDC otherwise?
  2. 05-14-2008 #3 songela Senior Tech 100+ Posts
    Join Date Mar 2008 Location dar es salaam
    That is one side with the fans,
    Secondly, if the fans are found right, then for sure you need to change the DC Controller.
    Regards!
  3. 08-02-2013 #4 mehta Junior Member Re: Canon GP 405 error E805
    Originally Posted by logimix
    Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
Apr 29, 2018 | Canon Office Equipment & Supplies
The canon Copier Brand iR2018 on the screen indicates a System Error E805, when machine is switched on.
Canon iR2018 Error Codes
This weblink states:
Code
E805-0000
Description
Fan failure
The fan is faulty.
Remedy
- Check the fan connector. - Replace the fan. - Replace the DC controller PCB.
Feb 16, 2018 | Canon Office Equipment & Supplies
Hello the problem is in my canon IR2016 showing
That means that fixing film ( Folie ) is worn out. Replace fixing film assy.
Jun 14, 2010 | Sharp AR-M350N Copier
My canon copier IR2016 has functional error E805
there could be a problem with the main fan and or the dc controller could be bad.
May 19, 2010 | Canon imageRUNNER 2000 Copier
E007
There is most likely an error in the rotation of the fixing film detected.
Or, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
Check the fixing unit
Jan 26, 2010 | Canon imageRUNNER C3200 Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Mar 22, 2009 | Canon CLC 1140 Copier
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 2000 Copier Logo
782 people viewed this question
old marine
old marine
