Question about Kenmore Elite Oasis 27052 Top Load Washer
Cold water good for a few minutes then slows to a trickle. Shut off for a few hours and cold water good again for a few minutes. Inlets are clear. Is this normal behaviour for a dying valve?
I have a Kenmore washer(110.15962400)which after a few minutes, the cold water slows to a trickle. Wait a few hours and cold water is good for another few minutes. Inlets are clear. I this normal behavior for a dying valve?
  • rjbreton May 23, 2009
    Thanks localwonder. I was able to pick up a new valve in town and have already installed it. Seems to have fixed the problem.
    Thanks again.
    Ron
  • 6,784 Answers
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
Posted on May 22, 2009
No cold water Running into Machine
Try checking for debris clogging the inlet of the washer. Shut off the supply water, then start the machine to do a warm wash (to relieve any water pressure in the hoses) for a few seconds - then shut off. Unplug from power and move the machine so that you can have good access to it and then mark and disconnect the hoses. Some machines have screen filters on the hose inlets. Check and clear out any obstructions you may find. It's not unusual to find sand, metal / rust chips, etc as can result from being pumped up from a well or an opened fire hydrant on the street due to a fire or the town simply flushing lines.
Before reconnecting the hoses - place and hold the ends into the tub (if possible) and turn the water on slowly to make sure that water comes out of both. This ensures that there is water flow all the way up to the machine inlets. You'll have to clear or replace any parts (hoses, screen, etc.) as needed to get water flowing.
If still not working - the issue can be a simple hot / cold water solenoid valve replacement ($) to something more involved ($$$). Check out the video to get an idea as to how to check out the valve (it's very similar to all machines).
Jul 13, 2015 | Washing Machines
Wm2032hw water filling slowly
The solenoids in the valve were sticking either because of sedement in them or them being faulty all together, which is likely the case since you said the screens were clear of debris, my advice is to order a new valve because the problem will happen again, its a matter of when
May 07, 2012 | Washing Machines
Cold water runs slow
Turn the cold water off and remove the hose at the machine. You will find a screen located there and you will need to clean it out.
Apr 27, 2012 | Washing Machines
Kenmore front loader washing machine very long wash cycle
You need to replace your cold water, inlet valve.
Unplug the machine from the power source. Disconnect cold water hose. remove the top cover of the machine. You will see the cold inlet valve/solenoide where the hose fits.
Take note of where the wiring goes. You can get the part from your appliance parts outlet.
Refit, and you should be right to go.
Good Luck.
Ash
Oct 22, 2009 | Kenmore Washing Machines
Is there a cold water filter on this machine. The
there is often a screen located in the hose end ... you can clean, replace or remove the screen and always replace the hose washers but its far better to replace both hoses with good quality new ones .. the safe lifetime of the hoses is only a few years ... so its a good idea to replace them every few years anyhow ... while you have the hoses off you can check water flow to make sure the shut off valves are not clogged .. (make sure they were both fully "on" to start with) .. if there is good water flow and the screens are not clogged then you may have a clogged solonoid valve (just inside the machine at the water inlets) (has wires going to it also)
Oct 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Kenmore Elite Oasis 27052 Top Load Washer Logo
130 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
