We have a Sharp AR-335 and it is giving an error
Where can i find the "program" "interupt" and "clear" buttons? Please help!:s
    Scholar:
  • 95 Answers
On the keyboard near the number pad. "c" is the clear button and I think program is "p" on that machine. Interupt is also up around the key/number pad. Its been a while, but Once you get into the maint/service mode, type in "14" and press the green start key. That will clear up any confusion the machine is havine unless its a fuser or laser code or something on those lines.
Posted on May 22, 2009
Ben in het bezit van een Sharp AR-335 machine. Geeft nu de CODE: U2-00 Hoe moet ik handelen om de machine weer normaal te laten functioneren?
Hello sir; You may reset this error code; the procedure as follow;
press"program" "interupt" "clear" "interupt",(interrupt also call pause key),then enter16 press start and clear.
Jan 06, 2010 | Sharp Office Equipment & Supplies
How to reset u2-40 for sharp AR266 photocopier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Jun 02, 2009 | Sharp AR-M205 Copier
We have a Sharp AR-335 and it is giving an error code of H3-00. Any idea what I might do to clear this error?
Hello sir; There is the way to reset;
1, press "program", "interupt", "clear", "interupt'.
2, enter 14 press print.
3,turn power off and back on again.
May 18, 2009 | Sharp Office Equipment & Supplies
Sharp ar 407
Hello sir;There have a procedure to reset;
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
Sharp Copiers Error code : F1-14
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Mar 02, 2009 | Sharp Office Equipment & Supplies
Error Code E 7
press"clear","interupt","0","interupt",enter14 press start.should take care your problem.
Dec 15, 2008 | Sharp AR-207 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
L 6
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Jul 02, 2008 | Sharp AR-M160 Laser Printer
Error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Jan 22, 2008 | Sharp AR-5320 Black and White Copier
55 people viewed this question
jasbo
jasbo
