Question about Samsung RB2155 Bottom Freezer Refrigerator
Refrigerator twice in the past month the bottom freezer has just quit for a few hours and then start back up again causing a mess and wasted food.
    Problem Solver:
  • 13 Answers
The freezer not running for several hours should not allow food to thaw. One thought is that the heater on the evaporator coils is not working.
Posted on Apr 08, 2008
Maytag MFI2269VEM2 Freezer issue. In the past two weeks, twice ice has built up in the freezer so much it is causing the fan to stop working and has been running really loud. Twice now we have taken the...
it is not defrosting. timer ,element , limit switch maybe issue. find defrost timer advance it see if compressor and fan quit running. when you advance this it should start defrost mode, which turns on the heater, which stays on till limit switch opens or timer advances, most are on 12 hour cycles
Oct 02, 2013 | Freezers
Amana fridgerator model bx21vc
First of all you did the right thing by putting all information in print, ,any don't , Any ways sounds as if some thing was loose, And sounds like it needs more Freeon
Aug 27, 2013 | Refrigerators
Started making screeching noise, started to spit
ok,,il be blunt,,,throw it away,,its past its best,,to have it fixed would be costly so do yourself a faver and just buy a new unit,,,,then show it off to all your friends,,,like look what iv got,,,eat your hart out!!!
it would be the cheapest way out of this
Jun 24, 2010 | Freezers
My Whirlpool refrigerator quits working and restarts
Good day,
If it only occurs on a monthly cycle, even a service tech would not find it unless it happened while he was there.
First choice would be to replace both the thermostat and the defrost control. These are the items that turn the machine off and on and either one could hang or stick once in a while.
NOW, that is based on the fact that the machine goes totally dead during that period. If you hear something, anything running then the above does not apply.
The possibilities then, are, the fan motor in the freezer won't run (you can hear it running when you open the freezer door), the cooling fan motor behind the bottom rear cover that cools the compressor and condenser same situation, will not run.
Lastly, the start relay mounted on the side of the compressor is weak. It will not kick in the compressor, but in that situation, the fans will run.
Hope that helps. I've serviced a lot of refrigerators with that complaint, and it's always been the first 2 items.
Feb 17, 2010 | Whirlpool ET1FTKXK Top Freezer...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Buyers Beware!
go to sears
Aug 14, 2009 | Refrigerators
Viking Pro VCBB36 -warming up + alarm
Over the past several years my heat alarm would come on, first time I called a PROFESSIONALLY, he told me to unplug for 24HOURS, than start it. The solution worked for two years, just happened again, unplugged it for 24 hours, and it seems fine. My guess it must need to defrost. Good luck!
Apr 22, 2009 | Viking Professional Series VCBB36 Bottom...
Kenmore Refrigerator Mod 70162990
It is under the evaporator you will have to remove the back cover... let me know if you want to do it and I will step you thru it...
Sep 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RB2155 Bottom Freezer Refrigerator Logo
118 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
