Question about Abit Fatal1ty AN8 SLi Motherboard
BEEPING SOUNDS LIKE SIRES FROM EUROPEAN POLICE CARS
I am having problems with my graphics card and thought it was settings in my CMOS so i pulled the battery and then replaced it. Now when i turn on the machine, it beeps sounding like a european police car. i have an AN8 mother board and an nvida 7800GTX. Any help would be great.
  • 2 more comments
  • jmosley292 May 22, 2009
    I have taken the ram out and replaced each stick each time with restart, no help it continues to beep during start up and then in to windows. It offers to let me go into my set up on start, or load windows. the beeps are duh duuh duh duuh or listen to a police car from europe. literally.
    yes a continuous beeping duh duuh duh duuh police car sound... but i can turn it on and surf the web but i dont want to break it. i was hoping it was a quick fix but.....
    TKS VERY MUCH
  • jmosley292 May 25, 2009
    Tks for all the information. I went to my set up and bios and disabled the beeping noise. I was having problems with my graphics card so im sure its the problem. So when i get cash ill buy a new one and enable the beeping again. tks so much my kids can now enjoy the free kids games on the net, and may be one day ill get back on EQ "crack" lol
    Jesse
    Evilbrood Outcast
    Inquisitor EQ2
    Talcon Defender
    Paladin EQ1
  • Abit Master
  • 4,806 Answers
Hi there.
Usually when the motherboard beeps there is a problem with some hardware or in most cases its the system memory that's at fault.
Get yourself a clean, soft, dry paintbrush, take the system memory out of the slots, clean the brass contacts on the memory sticks and also clean away any dust that may have built up on the slots that the memory goes into, after that blow any residual dust away and reseat the memory making sure its in nice and tight, then try to power up the computer.
Please post back with the results and if it still doesn't work please count the beeps and post back whether they are long or short.
Good luck and thanks for using FixYa!!
Posted on May 22, 2009
  • Lee Hodgson
    Lee Hodgson May 22, 2009
    so you are saying that it is a continuous beep? none long or short just continuous?
  • Lee Hodgson
    Ok.
    The computer has an issue with some hardware that's connected to it.
    Start by unplugging all the devices one at a time to troubleshoot which hardware it is, restarting the machine after each disconnection, if you have to completely disassemble the computer and re-assemble it making sure all connections are nice and tight and that all the fans work especially the CPU fan, try using the on-board graphics while you troubleshoot if you have it.
    Good luck and post back if you need anymore help or advice.
Hello, I have been running the non-SLI version of this same motherboard for about 4 years and have over 26,000 run-time hours on it (I used to run some personal web-server programs on it so most of the time the system is on 24/7)....If the fix that leecom72 gave you didn't work try this....
The "european police car" sound can also be caused from the system sensing a cooling fan failure. Check your fans, if they all look like they are running fine then go into the bios, uGuru page and check the fan monitoring settings. It may be set to monitor a fan that you don't have plugged in, so it thinks the fan has failed....in that case just disable the monitoring of that fan. Or it may be that the low speed limit for the fan warning is too low for a particular fan running at a certain voltage (as with this motherboard you can have the fan speeds vary depending on certain temps). If that is the case either turn the low limit down or turn the fan voltage up a little to get it to spin a little faster.
After all those hours of running this system I finally had the Northbridge chip fan start to, and finally fail....and each time the fan speed got too low the system would make the noise you describe. So give your fans and setting a check. If you need help on finding and adjusting the uGuru settings you can refer to your user manual or download the manual from the Abit website.
Hopefully I've been able to help with your problem..... =)
Posted on Sep 15, 2009
Blank screen toshiba laptop
the beeping sounds is possibly post your graphics card might be the culprit
the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery have secure dust free seatings
some motherboards cmos batteries are soldered in
test all power and data leads that attach to your hard drive the leads from your
(motherboard to your hard drive) Sata make sure they have dust free secure connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as a faulty fan lead can cause you problems a computer needs all of the power and data to travel through every working device and to
have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove your graphics card restart your computer the found new hardware should activate
hope this helps
Aug 17, 2012 | Toshiba Portege R705-P41 13.3" Notebook PC...
I have a P4 computer.It is having a SD RAM. Yesterday i cleaned MY PC after cleaning MY PC it is not working.No display is coming.things i have done is removed and replaced RAM, Chip set and graphics card
try to change the cmos battery of your motherboard(CR2032) then look for the clear cmos jumper on the motherboard. also clean the terminal contacts of your graphics card and memory card with the aid of eraser.this should solve your problem if there is no defect on the mainboard, ram or graphics card.
Apr 26, 2011 | Computers & Internet
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
I am facing a problem to install my XFX Radeon HD 4350 1GB graphics card. My PC has a intel DG31PR with core 2 duo and 3 gb ddr2 RAM. the CPU starts but there is no visual on my ACER monitor. I have...
It sounds like you need to change a BIOS setting. I don't have this MoBo, but on others there is a toggle to make the integrated graphics primary or secondary. You would need to change it to secondary. On this card this should happen automatically - so check BIOS settings and that your new card is properly seated in the slot.
From http://www.intel.com/support/motherboards/desktop/sb/cs-022225.htm
Installing External Graphics Cards
If you want to install a 3rd party external graphics card instead of using the onboard graphics, follow these steps:
  1. Install the 3rd party external graphics card, following the installation instructions that come with the card.
  2. Integrated graphics is automatically turned off.
Jan 10, 2011 | Intel DG31PR Motherboard
Problem installing graphic card radeon hd5670. After installing the card in the PCI slot the pc cannot boot up properly but if i remove the card it can boot up smmothly without any problem... Help me with...
with the video card use on motherboard first or did you add on the motherboard if motherboard was used first you will need to turn off in cmos if you were useing motherboard and not card first.set in cmos video card to auto then save changes reboot install card then drivers ok jim
Mar 26, 2010 | ATI RADEON Graphic Card
No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
Aug 13, 2009 | Computers & Internet
Computer failing
does the computer make any beeping noises during boot ??? if so how many
May 22, 2009 | Gateway GT5670 Desktop PC
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
Remove a memory module.
If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module.
Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
If the computer has a graphics adapter, remove it.
If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step.
If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
Remove a PCI card.
If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card.
Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket.
If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing.
Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case.
May 12, 2009 | Intel Motherboard
Beeping when running games
What tempretures are your cpu and gpu running at during games? use speedfan for cpu and rivatuner for gpu. Both are free programs. sounds like an overheating warning to me :)
Dec 29, 2007 | Chaintech SA5700L GeForce FX 5700LE, (128...
Open Questions:
Abit Fatal1ty AN8 SLi Motherboard Logo
613 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
