Question about Brother MFC 240C All-In-One InkJet Printer
Cannot print blue/green colors.
MFC-240C Blue/Green Color not printing. Comes out as yellow. In general the colors are all off but blue/green is the worst. tested color using : http://suda.co.uk/projects/color/ct2c.pdf
Try cleaning the heads - mine wasn't printing blue or green either and it cleared up the problems (had to clean the heads several times).
Posted on Sep 29, 2013
  • 133 Answers
I think your cartridge is defective, you need to replace a new cartridge.
Posted on May 22, 2009
HI, when printing in colour the blue appears as partially green
Usually this happens in inkjet, when you have a mix of the colors int he cartridge.
so, inkject usually have 3 colors, Blue, Yellow, Red.
If yellow color finds it's way towards blue, then instead of blue, you will see green.
Solution: change cartridge.
Aug 01, 2011 | Office Equipment & Supplies
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
False colors
Replace the "red" (or the "tri-colour") cartridge.
Jan 25, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink on my Brother MFC-420CN is faint and streaky
You said you replaced the cartridges. Were they Genuine Brothers' Cartridges?
My Brother MFC-240C, does not like Generic Printer Cartridges. That sounds like your problem. Also I had with Brother's was problem with Color. Color that should be Yellow, will turn out Green, or Blue Green, etc. The Generic Cartridges, also printed lines thru the words. That's what the Companies do., so they can keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY, or Take them to have them filled.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 03, 2010 | Brother MFC 420CN All-In-One InkJet...
When printing a photo has a yellow/green tint. All other functions work it prints and scans great. Just have a problem with printing photos.
Possibly it is running low on Blue ink - because colors are usually a mixture of inks - for example green is made from blue and yellow - if an ink runs low it will print the available colors or substitute the next available color.Probably if it prints green yellow - then it has no blue available to make the right shade.
Oct 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Prints blue and black only
I have had this happen on mine as well. The nozzles are not clogged (which cleaning would fix) the lines going between them and the cartridges most likely has a clot in it. Call in Brother's tech support and have it replaced by warranty, I have so far replaced for the same problem twice.
Jul 28, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
551 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
