Question about Dell 3100cn Laser Printer
Tray Error, Invalid Config
I'm getting a Tray Error, Invalid Config message when the 3100 comes on, and I can't do anything else with it.  Looking on the web interface, it looks like the problem might be with the Center Output Tray, because even though its status is OK, it's highlighted red.
Another comment in here said to unplug while the printer is on... that didn't work for me.  Any suggestions?
Thanks.
    Scholar:
  • 132 Answers
You can restore the original factory default menu settings by initializing NVRAM. Try this and see what happens. from there I would need an exact message off the printer to help further.
Turn off the printer.
Turn on the printer while holding down Tray Error, Invalid Config - u_botton.gif and d_botton.gif .
The Customer Mode menu appears.
Press Menu.
Press d_bottonb.gif until Configure aTray Error, Invalid Config - r_bottona.gifhen press or arrowbutton_sa.gif .
Press d_bottonb.gif until MaintenanTray Error, Invalid Config - arrowbutton_sa.gif and then press or .Press d_bottonb.gif until Init NVRAM appears, and then press or arrowbutton_sa.gif .
The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
Turn off the printer, and then on again.
Posted on Oct 19, 2007
  • Sandy Chamberlain
    Sandy Chamberlain Oct 19, 2007
    Turn on the printer while holding down up
    and down buttons
    Press Menu.
    Press down
    until Configure appears, and then press select .
    Press down
    until Maintenance appears, and then press select
    .Press down
    until Init NVRAM appears, and then press select
    The Init NVRAM Are you sure? message appears on the operator panel. Press select
  • brad tassainer May 17, 2013
    start to do this then can't get passed customer mode when i press menue then press down nothing happens
Samsung clx-3150 paper jam. it will only feed 20wt paper from bottom tray. anything else stops and i get a paper jam 0 error message
Check the specs operators manual or go to the Samsung web site look up the specs for your machine. The weight of your paper may be greater then the machine can handle.
Nov 17, 2015 | Samsung Office Equipment & Supplies
Tray error invalid config
Message:
TRAY ERROR INVALID CONFIG
What this message means:
The printer detects an incorrect configuration of the trays.
What you can do:
Turn off the printer. Set the trays in the proper configuration again.
See "Installing the Optional Tray Module" in the manual book.
Please find below a link to give you a brief idea on the process. Exact details can be viwewed from the manual only:
http://www.csudh.edu/CLASS/voffice/dell3100printer/Contents/section08.html#513263
Sep 10, 2009 | Office Equipment & Supplies
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
Tally6215 "Config 1" Error
The 'Config 1" message on the T6215 is not indicating an error message, this message is simply indicating that Config 1 of the 10 configurations that you can set on the T6125 is loaded.
With the Config 1 message loaded you should still be able to print so long as the printer is ONLINE and does not have any other error lights on.
If the printer is not printing I would recommend printing a configuration page to check the printer is working OK.
To print a configuration page follow these steps;
Put the printer OFFLINE
Press the MENU BUTTON
Press the DOWN ARROW to HELP
Press ENTER
The printer should print a configuration page, if this prints correctly I would recommend checking the settings in particular the Interface and Emulation settings.
I would also recommend checking connectivity between the system and the printer to check the print jobs can get to the printer.
Also check the system to ensure the correct printer driver and printer setup is being chosen.
Mar 26, 2009 | Tally T6215 Matrix Printer
IP IOS Command not working with switch
you want to give IPs to your VLANs and also make physical interfaces members of a VLAN instead of giving IPs to physical interfaces
Mar 05, 2009 | Cisco Catalyst 2960 8-Port Ethernet Switch...
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
Error: Invalid Dim
this happened to me as well. i looked it up and heres what i found:
http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot"
one of them is turned on so press enter and select OFF. this should fix the problem!
Sep 18, 2007 | Texas Instruments TI-83 Plus Calculator
Tray Error - Invalid Config
Unplug the power cord well the printer is on. and it should reset it worked for me. Hope that helps.
Apr 25, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
1,204 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
