Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Network Card Issue
I have a Dell Dimension 5100. We just got broadband set up and it would not work correctly. It works with another laptop - but does not with with the PC. After hours troubleshooting with the ISP, they say they think we need a new LAN/Network card. I called Dell to ask about this and they said we need a new motherboard.
Can anyone think of anything else that could be causing the internet issue apart from the network card?
Also, is the network card a part of the motherboard? Is it really necessary to get a new motherboard if it's just the network card that is not working & the computer is working fine otherwise?
  • anitaoflynn May 23, 2009
    Thanks for all your help so far. We were trying to set it up wired and the laptop worked when connected with the wire also. The lights were all green - everything seemed to be working fine from the modem side of things- but we just couldn't connect on the PC.
    So, if I understand the other answers correctly, we can buy a stand alone LAN card and connect it to the the PC? Is that easy to do?
    Badically we are looking for the cheapest solution - Dell said they can get a guy out to fix it for e350 - but a new computer would only be around e450 ... so maybe we should just forget it & get a new one.
    Any advice is really helpful - thanks :)
  • Carlos Soto
    Carlos Soto May 11, 2010
    Is the Dimension setup via wireless or wired? When you say it works with another laptop I need to ask if the laptop was connected via a wire or wireless?
    Assuming you are wired, once you plug in the network cable, do you see any lights? Amber/Green blinking in the back?
    To answer the question if it is built in, the answer is... it could be. Some have them built-in and some don't. However, if is is built-in you can add a network card to your machine and use that. But let's work on the issue as it stands now.
    Looking for your reply.
    President:
  • 688 Answers
On your dell the lan card is integral with the motherboard.
go to your device manager in the control panel and find your ethernet card. you will see it with a yellow triangle , right click it and update driver software.
if it doesn;t find a driver , write down the ethernet type and model specs and search the internet or dell support forum for the driver.
reinstall the lan driver and see if it works.
also: some ethernet configurations are not compatible with some isp's. i doubt that for your dell but there may be a driver patch available to bring your driver up to date.
Posted on May 22, 2009
  • Steve Brown
    Steve Brown May 23, 2009
    You can go to Best buy or any store and buy a 10/100 ethernet PCI card for pretty inexpensive.
    open the computer and plug it into the Open PCI slot and put the screw in holding it in place.
    close the box hook it back up and turn it on.
    It may install the drivers automatically but if it needs put in the cd and point the driver install to the drive.
    then try your internet
    Well after you plug your cable in of course
  • 700 Answers
Commonly its plug and play when you hook it(broadband) in the LAN its just automatic. Could be LAN driver issue or so as they say.
Could be the network card is built in with the motherboard but you can use another Lan card and plug it in a PCI slot then install the driver. Just disable the built in one to make it sure it doesn't conflict with the new one.
Then set everything to auto detect.
  • 159 Answers
My friend if it is not on board network card, un plug the card and replace with the new one and then u make sure that u follow the instructions given when installing and also u have to configure again the ip adress or net work set up as before
  • Paul Ssebata
    Paul Ssebata May 23, 2009
    No a net work card can not cost that much, try other suppliers, or you can also try any other type it can work with dell ie toshiba,hp and etc
Can't get 1600x900 Resolution
Your graphics card may not be able to display this screen resolution.
Open Control Panel - Display - Settings tab and move the slider on the Screen resolution - to get as close to 1800 X 900 then click apply.
Mar 21, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Network can send packets cannot receive packets Modem and Cable checked out okay with another computer ethernet working okay. Windows xp home on dell dimension 5100. cannot ping to internet.
You can contact The Best Pc Doctor team for any technical help. Their contact details are given below.
www.thebestpcdoctor.com
877 407 9229(Toll free)
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
What kind of sound card do I need? I can't get any
The dimension 4600 has an integrated sound card, but if that is not working and a driver update does not correct the issue, then any sound card that used a PCI interface will work with that system.
Dec 26, 2009 | Dell Dimension 4600 PC Desktop
There is no sound in the right channel of my Dell 5100 desktop running XP pro
check rear speaker connection to make sure plug is fully inserted in PC. if this doesnt work try using a different set of speakers. if still just mono then replace sound card.
Jun 09, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 2350 wireless connection works / wired doesn't
have you tried replacing the network cable,also try a different port on the router
Mar 25, 2009 | Dell Dimension 2350 PC Desktop
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No videon
it sounds like an issue of driver installation order. If not installed in the correct order, the drivers may not function correctly. The correct order is:
Desktop System Software
Chipset Utility
Video Driver
Audio Driver
Modem Driver
Network Driver
My suggestion is to do a system restore to the 1st available restore point (The one created at boot after you reinstalled) then install the drivers in the correct order. (NOTE: Before you can play a DVD, you will have to install the DVD player too)
Jul 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wireless internet
you need to get a PCI Wireless card or a USB Wireless adapter, if you are talking about an 802.11 wireless router.
If you are talking about Sprint wireless Broadband or the link (WWAN service) you'll need a USB WWAN adapter which are available by all major Wireless vendors (Verizon, Sprint, ATT etc(
Jun 25, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dimension 4550 10 100 Network Problem
chk in the device manager if the netwrk card is listed correctly.....also try disconnecting & reconnecting the cables
Jun 23, 2008 | Dell Dimension 4550 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
592 people viewed this question
Alun Cox
