Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
Wirless netgare router setup
I can not connect my utstar modem to netgare wirless router plz help modem works fine when connected with wire but dose not work when connected to wireless router
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on May 28, 2009
I have cricket broadband wireless internet, how do i set up my belkin wireless router to it so i can send out a internet signal to another source?
You cna get the router manual on the below link free link
http://dl.owneriq.net/8/81c69071-e6b4-da74-6921-04cb37aa97a5.pdf
Also you can follow the below steps to set it up
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
Let me know if this will help
Regards
Dec 04, 2009 | Computers & Internet
My modem works fine when i directly connect 2 the CPU,and when i use the router and connect it don't work........the power,wirless,LAN,are all green and the intenet(Modem) is orange.....help plz =/
If your with cable ISP you need to mac clone the mac address of the pc to the router.
1.make sure that everything is connected properly (modem to internet port of the router and pc to regular port)
2.access the router, http://192.168.1.1 (username: admin / password: password)
3.under basic settings page, scroll down to the bottom and look for router mac address and select Use Computer MAC Address and then hit apply
4.click the router status on the left pane and check if there's an IP under internet port, if yes it should be working and if not you need to power cycle the network
5. to power cycle, turn off the router and modem for 3 minutes and then turn on the modem first and then the router
5.it should work now
Jun 28, 2009 | NetGear WGR614 Wireless Router
I lost wireless internet when i connect internet from my modem to computer it works but the router shows no internet the computer picks up the router and the computer says it is connected wirless but not
Did you at one time have internet? Another thing that it could be is that your modem is going out. I would test the modem and see if it works, then connect to then try connecting it back to the router and restarting both your modem and router. And finally it may be actually be disconnected in the setup so look at your setup on the setup screen by opening internet explorer and typing 192.168.1.1 then configure your router's connection one more time.
Jun 24, 2009 | Linksys Wireless-G WRT54G Router
I had my DSL disconnected. I am using cable internet w/Comcast. I've DIR-628 connected to Mot-SB5101 Cable Modem. This setup is working fine. However I'd like to use my old DSL/Router 2wire 2701 to connect...
First you should see a wirless icon on the botom left of your screen wich is on the task bar. The say view wirless networks or what ever it would say then you should see a list of avalible networks at that time. The slect the network that you own an say conect. When conecting it way ask for a WEP password which is located on the router. I hope this will help you.
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Connecting a modem and router to my desktop
When you connect all the devices make sure you reset them all after plugging them together. Also use a different ethernet cord and make sure your plugging the Modem into the WAN port on the router. If your still having same problem just let me know.
May 08, 2008 | Linksys Wireless-G WRT54GS Router...
Need Belkin Disc; same problem with setup
R u connecting through the wired connection or wireless connection ?
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
I want fast help..how to get connection between linksys router and aztech modem
first check..
Step 1:
Step 2:
Step 3:
Step 4:
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
349 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
