Question about Galaxy Radios DX-95T Base CB Radio
Talkback sqeels when it decides to work!
I have a galaxy44 and my talkback has a mind of its own,it works when it wants to ,but when it does work i get a squeeling noise most of the time!,please help!!!
    Problem Solver:
  • 10 Answers
The squealing you are referring to is usually due to to a disabled automatic modulation control circuit.
one or more dry solder connections could cause the intermittent operation.
Posted on Jun 10, 2009
How to get talkback turned off
Hi Michele
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
Feb 29, 2016 | Cell Phones
Tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
on Oct 15, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
Radio worked fine when bought 2 days worth went to key up mike only sound is a sustained whistle sound,took to repair shop had fixed guy said he rebuilt talkback worked again 2 days same result sustained...
Do it have a relay mod for the talkback if so take that thing out. use the normal talkback. We are in TX.. no charge to check out.. I would check to make sure it has just plain normal talkback, and no other mods done first.. any other mods done??
Mar 19, 2011 | Connex Radio Communications
I have a dx98vhp and it sqeels* when i key up when the talkback is on. I've tried adjusting the power and i can't figure it out. Thanks
the talkback is too loud. there is no way to adjust the talkback volume on this radio. Talkback is really just so you can check how your audio sounds and your echo. Once it set, there is really no need to have it on.
Turning down the gain on your mic will stop the squeal.
the squeal is cause by feed back from audio from the talk back being heard from the mic.
Sep 14, 2010 | Galaxy Radios Microsystems DX98VHP CB...
I cannot talk or hear my friends talking on the Earforce X31 headphones
Just replace your talkback cable, and your headset will work good as new. You can purchase the talkback cable here:
http://www.turtlebeach.com/products/efx3a/replacementparts.aspx
May 08, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
Want to get talkback in a cobra 29
When you key up the mic ungrounds the speaker so you don't hear anything through it, so to get talkback you're putting a 100 ohm 1, or 2 watt resistor between the switched side of the speaker and ground, now when unkeyed the mic grounds the speaker as usual, but when you key the resistor allows a bit of audio from the audio amplifier, not decoded RF, to still get through. I think the pa/ext spkr. jacks are a convenient place to connect it. You may decide to control talkback by running the circut thru a switch like brite / dim switch . Want less talkback, use more resistance, 150 ohm . Too much talkback can become feedback . I hope this helps, J
Nov 25, 2009 | Cobra 29 LTD CB Radio
I have a Cobra 29 wx classic and i get talkback through the speaker, and it doesn't have talkback installed!! How do i change this and what is wrong!! The radio works awesome rx/tx, but it just has this...
Have you tried using a different mic that you know is working properly? If it still has feedback, then someone has installed talkback. Take the top off, check for a resistor between external speaker and pa speaker ports. Remove resistor if it is there and that should remove the talkback. Hope this was helpful.
Jan 15, 2009 | Cobra 29 LTD CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Galaxy Radios DX-95T Base CB Radio Logo
102 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
