Question about GoVideo DV2150 DVD Player/VCR
Vcr won't record on timer
I follow all the instructions, set the timer as told, and the icon for timer comes on just as it should.  But when the appointed time for recording comes, it doesn't switch to "record" and the icon starts blinking (meaning "faulty recording" supposedly.  Cannot make it switch to record without intervening manually, which you can't do it you aren't around when it's supposed to start.
  • JJMKSM Nov 29, 2007
    MY DV2150 ==
  • 4,102 Answers
When you set the timer you need to ok the settings of the programme you record then you need to switch the video off on the controll as it will only record in standby mode cus if the video is switched on it will wait for you to tell it to record hope this helps
Posted on Oct 30, 2007
How to turn off timer setting and put in a new program
Hit the menu key and select the recording options. Select the option to view timer recordings and select each one to clear it. Follow the onscreen instructions or when on a recording hit the clear/delete button on the remote.
Feb 19, 2014 | Rio Go Video SDV-650 S-VHS VCR
Www philips com support
This unit doesn't have a tuner of any sort. Even on the few DVR/DVD recorders that have tuners, the external composite video inputs do not connect to the tuner. To record from the L1 or L2 inputs, you must be using a set-top box (cable, satellite, or digital-to-analog converter for OTA signals) or another video source (video camera or a vcr). Most TVs do not have video output capabilities. If you have one of those, follow the directions for recording from set-top boxes below.
Turn on and set the source to the channel that you wish to record for any set-top box. Then make sure that the set-top box is left on and at the correct channel after you finish setting the frequency, speed and length of time for the recording. Note: if the set-top box is turned off, your recorder will still record the blank video and audio.
What source do you have connected to the VCR?
To record from a video camera or a VCR, set that source to play back at the desired time point. This is best done without the timer. Just start recording and then the playback.
I hope this helps. Please add a comment with your video source for more support.
(My OTA tuner has a energy-saver option that turns off the unit when there is no activity for a while. Since I usually record when I'm either asleep or away from home, I had to disable the feature to get the correct recordings.)
Jul 04, 2013 | Philips DVP3345VB/F7 DVD Player/VCR
I would like to record a show/shows on tv using my lg gc990w 6 head hifi stereo vcr . A work colleage has told me I cant do this because I am trying to record a high definition channel. Is this true or...
you can try setting your tv to record and your vcr to record at same time,,,i have digital tv and set record time,,then on vcr set to record avi at same time,,the only problem is the tv turns itself on when timer starts,, hope this helps and makes sense,,cheers.
Feb 08, 2011 | LG Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
• After timer recording is completed, the VCR turns off
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
Press SET –/+ to select one of
the program lines, then press
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
Aug 28, 2010 | JVC Televison & Video
I need instruction to set recording for sharp h952 vcr
You need remote to get menu to set the clock then go to timed recording setting. Then you load a new tape, then shut down the vcr and wait for the timer to start the vcr and recording for you.
If you need a manual, google for sharp vcr manual download free from sharp website.
Aug 26, 2010 | Sharp VC-H952U VHS VCR
The timer used to work with analog cable TV but it does work with our cogeco digital cable TV. When the timer goes on, the little red VCR icon vanishes which means we are recording a blank, blue screen....
Some TV's output the signals for recording in different ways. It depends on how the VCR is connected to the TV. Have a look around the TV's menu or the instruction manual to see if has a setting for outputting signals to VCR's.
Mar 22, 2010 | Televison & Video
Samsung DVD-4600 won't record with VCR timer set
Press fast forward and rewind button on the unit simultaneously for 10 seconds with no disc inside the player to reset it to factory setting.
Aug 19, 2009 | Samsung Televison & Video
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Phillips VCR 550
it only the time setting not cable
Jun 05, 2007 | Philips VR550 VHS VCR
GoVideo DV2150 DVD Player/VCR Logo
110 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
